Old 27th September 2011, 03:33 PM   #1
ARCANE is offline ARCANE  United States
ARCANE's Avatar
Default Re-foaming Dynaudio 21W54
Does anybody know a good place to have 4 Dynaudio 21W54 re-foamed?
They all are in need of a new suspension and I do not feel like I can do it myself.
Thanks for any pointers.
Yves
Old 4th October 2011, 06:20 PM   #2
WTS is offline WTS  Canada
I'm also looking to get the surround repaired on a 30w100 bass driver. I just recently moved and the mover damaged the surround. At one time I thought I had heard that Dynaudio would repair the drivers.
Walter
Old 24th October 2011, 09:44 AM   #3
Default trphoto
Have had the same problem.
Try Speakerbits in Melbourne, Australia for repair kit, which includes original foam surrounds, shim material, glue and clear instructions.
It's relatively easy to do, hardest part of the job is getting the remains of the old foam and glue off the cone and chassis. I used cotton buds and lighter fluid which works well but takes time.
I am no engineer, but found no problems doing it myself!
Old 26th October 2011, 12:03 AM   #4
There are 3 or 4 large recone shops in the US who can refoam Dynaudio drivers - just web search for speaker repair shops
Old 26th October 2011, 01:43 AM   #5
Audio Junkie
Zero Cool's Avatar
I am having a set of 21W54 drivers done right now as a matter of fact! the ONLY shop i know of that can do Dynaudio woofers correctly is Bill Watkins! Professional AND affordable speaker repair and refoam by Watkins Engineering
almost all speaker repair shops cut the dustcap off a woofer to place shims around the voice coil to center it on the pole piece.
Bill has a proprietary electrical method of centering the voice coil without having to cut the dustcap off and Dynaudio woofers do not have a dustcap! he is the only person i know that has a process like this!
Dynaudio no longer sells drivers to the public and they do not refom woofers. I just asked them the same question about 3 weeks ago!
Bill will Do Dynaudio woofers but you will need to buy your own foam kits. Orange county speakers has the kits for $50 per pair. they claim they are the technically correct foam kits imported from Germany. Bill charges about $95 per pair plus shipping. so you are looking at about $300 to have them done correctly!
Zc
It's not about what you can BUY...It's about what you can BUILD!
Old 27th October 2011, 08:14 PM   #6
wingman is offline wingman  Denmark
there is only one right way to centering a Dynaudio woofer, and none of them written here is not one of them.
bass is also audio
Old 7th November 2011, 07:01 PM   #7
Okay, so can you tell us what is the correct way to center a Dynaudio driver when replacing the suround?
Walter
Old 7th November 2011, 07:08 PM   #8
ARCANE's Avatar
I had my speakers re-foamed by Bill Watkins. It was not cheap and the labor + suspensions for all 4 Dynaudio speakers amounted to close to $500.00.
However, the result is fantastic and the basses have never been so good on my system: very sharp, precise and full of impact.
Expensive but worth it. I also rewired the wires inside the Puppies.
Yves
Old 7th November 2011, 08:04 PM   #9
DaveG is offline DaveG  United States
Hi Yves,
Did you provide the surrounds? I purchased a set that waswrong, so am looking to confirm a correct vendor.
thanks
Old 7th November 2011, 08:16 PM   #10
ARCANE's Avatar
Yes I did, and got them form Orange County speakers (as indicated above in the thread). The reason why Bill Watkins charges so much per speaker, is because it is very labor intensive and he has to work below the speaker frame/armature. The suspension are glued behind the cone, not on top of it. He offered to glue them on top which would have saved a lot of money, but I declined and wanted them to be like the original.
It is still a minute amount compared to what Dave Wilson would have charged to fix the speakers.... :-)
Yves
DYNAUDIO 21W54, 08 Ohm, 4pcs. makus Swap Meet 4 27th August 2011 09:38 AM
Dynaudio 21w54 slatki Multi-Way 2 13th January 2009 09:39 AM
Replacement for Dynaudio 21W54 ? TrevorSt Multi-Way 3 15th April 2006 08:05 PM
NEEDED: Dynaudio 21W54 8" woofer KBK Swap Meet 15 6th December 2004 06:44 AM
WTB: Dynaudio 21w54 (1 or a pair woofer) bng Swap Meet 0 21st June 2002 12:24 AM
Page generated in 0.12803 seconds (66.03% PHP - 33.97% MySQL) with 10 queries
