#21 |
If you need to go also low, IB installation using attic as backspace is one option. Then you need just 8 LMS-5400 with 30kW or 12 FI IB318 with 11 kW.
Simulation have 4'th order high pass at 15Hz to get more output without bottoming drivers below 20Hz. Room should add few db to low end. |
#22 |
Build 4 TH-18's with whatever driver you want, and use the 3015lf's you currently have for midbass....
and add another RMX 2450... |
#23 |
This the the link to the spreadsheet I used to come up with my numbers.
In the past I have compared it's figures against other speaker design programs and is at least within 10% and/or better with the figures from winlsd. So,Anyway, I trust it. Yes you can get 140db at 50hz fairly easy,But as you go lower your displacement requirements go up drasticaly. justint, Had specified 40hz so I was going for a lower frequency's of 25hz to 35hz as this would help to compensate for the extreme excursion and thus lowering the THD at 40hz at that level. Although you may not hear the difference in the room, But, If the system was outside you would. http://www.linkwitzlab.com/spl_max1.xls jer |
#24 | |
justint built don's upandback TH that goes low(er), is small(er), and gives up some spl. The ss15 wouldn't quite get there in pairs in a perfect corner... but it gets in the ballpark. The tradeoff? no 35hz. Others have found 32hz 24db/oct butterworth high pass will let you get some under 40hz in a ss15 while keeping it safe within xmax bounds. The room will depend on how 'flat' it actually gets below Fc. If you are a spl nut, and have others that live in the house with you.... I can't imagine bringing in anything bigger than a pair of ss15. It'll get you spl, you just have to give up the really really low notes. |
#25 |
1 th ~550ltrs with 18 sound 21nlw9000c with 2000 watts input(no compression calculated)
one good thing about music ,when it hit you feel no pain. so hit me with music. |
#26 |
To the original poster - You do know that exposure to 140db causes instant hearing loss?
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#27 |
Unfortunately, it won't fit. But it would do the job. Oh, and you need 14kW for the bass section.
#28 |
Here's the very, very easy way to do it:
Build a large sealed enclosure, say about 3x4x6 feet. Design it so that the back can hinge open and install a normal 12" subwoofer (Free air type?) in the baffle. Power with 100W, that's plenty. Now here's the trick: to listen to the subwoofer, open the hatch, get inside, and lock it behind you. Inside the small "cabin" the SPLs will easily reach 140dB, and you will not cause any structural damage to your home although your hearing will likely be destroyed in only a couple of seconds. This is why it is possible to launch those stupid SPL wars in a car, but not in a home. Duh. -Charlie |
#29 |
Ahhhh,ha,ha,ha,ha,ha Too Funny!
Nice System ,wg-ski, I like !!! jer |
#30 |
now that there is funny stuff -- I don't care who you are......
| Anyone IB their House? | dzzmiller | Full Range | 1 | 19th March 2009 10:54 AM |
| 15s8530 - reaching xmax? | BNK | Multi-Way | 6 | 14th September 2008 10:58 PM |
| forum project 4932: make something that can do a good 140db at like 10hz | travis | Multi-Way | 28 | 21st February 2005 03:51 AM |
| Ghost in the house??? | bowdown | Solid State | 12 | 16th November 2004 01:08 AM |
| Reaching for the "highs" in a speaker | WildWest | Multi-Way | 2 | 23rd May 2001 09:00 PM |
| Page generated in 0.10618 seconds (80.16% PHP - 19.84% MySQL) with 11 queries |
