need help reaching 140db in my house!!!!
Old 14th November 2011, 03:58 PM   #141
GloBug is offline GloBug  Canada
Banned
Originally Posted by doug20 View Post
+1,
It seems like a bunch of boring old retired people warning the young guy to stay away from drugs/acohol and women...Yawn!!!
Either people have a design that can help the OP or they should worry about their own sorry little world more (some need to!!).
-or-
Just pass the geritol so we can all have the same buzz kill
Maybe the true problem here is that most here have crap little spaces to deal with, did anyone outside of NeoDan realize that space???? I have a 50x30x12 family room with raise kitchen....We need SPL for parties. Its not my fault your house can fit in my family room or you do not have enough party life in you any more.
Sorry OP, the regulars here are 70+ years old and live in shoe boxes
Dude I'm 32, you guys sound like idiots.
You sound like a 16 year old with factory speakers in his car and a crap overrated sub rattling his license plate.
Want my advice, put a bigger wing on it and add some neon, then gay VinDiesel will come to your dance party.
Old 14th November 2011, 04:25 PM   #142
justint is offline justint  United States
Bug i almost have to laugh. this is like telling a skydiver not to jump because its dumb.. I have a dedicated high end theatre room in my basement if I want to spend thousands in my living room on a ridiculously unnecessary stereo then I will..
Old 14th November 2011, 04:34 PM   #143
Banned
I was more offended by how some are treating the older crowd, I agree you should do what you like. Have at 'er. AL
Your skydiving analogy does not work because it is proven it works time and time again. Millions have done it.
Now if your parachute had holes in it, or your too fat for it....then maybe heed the warnings.
Old 14th November 2011, 05:29 PM   #144
18Hurts is offline 18Hurts  United States
I wanted 125dB at 20Hz in my house
Built a sub that hit around 115 to 120dB at 20 Hz as large picture window was flexing and rattled in the frame, the HVAC vent started to rattle, the doors in the house where hammering away and even the garage door joined in. Calculated that was the structural limit in my living room as I don't want a giant piece of glass coming down and cutting my head off. The curtains get closed for movie night just in case.
Moved my project out to the detached second garage. Metal walled building with plywood inner walls, two small windows, concrete floor and plenty of space. It's just sound, so I scaled it back to THX IMAX levels at the seated position or 110dB highs and 121dB at 18Hz for the low end.
I'm an "old man" in my 40's with great hearing since I took care of them in my 20's/30's running huge PA systems. I do enjoy watching 20 somethings walking right up to my vertical line arrays to "rock out" and seeing the puzzled look on their faces when they do--as you get closer to an array the woofers/tweeters go off-axis so it does not get much louder-- The slight increase in SPL when right up on them does not make up for the bass shift--they step back around 2 to 4 meters and it sounds "right"... The "anti-idiot vertical line array" works very well for that function.
Personally, I could care less if you smoke your hearing--want to borrow a boat air horn and put it up to your ear? Go deaf...win a prize. The issue is deep bass will break things in a structure--the ceiling can and will collapse which is a bad thing when others are in your room. I fully support everyone's right to blow their hearing or injure/die from structural failure from infrasonic bass frequencies--only if it is you! Once the stupidity level then starts to effect other's well being...that is the line.
How to identify is someone is stupid? Simple, the larger the room gets at the same sound level--the more likely you'll have structural damage. Smaller rooms are more solid in construction (ask tornadoes) Unless your mommy and daddy own a cathedral or underground bunker--it would be best to respect the building when living in the basement...
Old 14th November 2011, 05:50 PM   #145
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
WOW,
Is everybody off their meds?
RELAX!!!
OP scaled back to a single 15" for low sub duty.
Dan
Old 14th November 2011, 05:53 PM   #146
Banned
You relax, MR.CAPS LOCK.
If I was of my meds you would know it.
lol AL
Old 14th November 2011, 07:27 PM   #147
Josh Ricci is offline Josh Ricci  United States
I have a LF system that will legitimately do 130dB @ 16Hz in the middle of a 10K room and I'm not sure what above there. Let's say it's a lot. I have driven it pretty loud with the bass ridiculous hot a couple of times just for fun. Demoing for friends, etc. (Jurassic Lunch anyone?) Nobody in their right mind would listen near that loud for more than a demo here and there. It's just uncomfortable loud, at least for me. Yes the building structure was making complaints during the real deep bass but it wasn't in danger of crumbling with a few blasts here and there.
What level do I usually listen to this system at? I don't know, the peaks are maybe 110dB. Just because someone wants an insane amount of headroom does not mean that it is going to be used very often. Maybe they are like me? I just like to know that the system has plenty of headroom left in the tank for ANY material I will throw at it and that it is operating at <25% most of the time = Low distortion, low compression, effortless dynamics reproduction. I don't have to wonder. Plus it is fun to blow the cobwebs out of the rafters every once in a while.
That's my 2 cents and perspective on wanting massive headroom.
Old 14th November 2011, 08:43 PM   #148
I will try and run sum #'s and tests tommorow.. I have to support my Green Bay Packers tomm.. Also Neo is it possible to check if I switch to the dual 4 ohm L7 15" if anything changes on my #'s that way I can have the QSC feed it 1200 watts .. Thanks for all the help!!
Old 14th November 2011, 10:21 PM   #149
NEO Dan's Avatar
I'll check this evening. I'll post in the other thread though.
Dan
Old 15th November 2011, 04:56 AM   #150
geraldfryjr is online now geraldfryjr  United States
Originally Posted by justint View Post
Ok so I built another box and it starts getting crazy over 130db and especially over 120 around 30hz . I got light bulbs popping from the vibration, silverware jumping around in it's cabinet light fixtures rattling, fireplace sounds like a tin can, I am getting nauseous from the lower frequency .. Just plain ridiculous but I love it thanks for all the help but low 130's is plenty for this guy
Cool !!!
jer
need help reaching 140db in my house!!!!Hide this!Advertise here!
Anyone IB their House? dzzmiller Full Range 1 19th March 2009 10:54 AM
15s8530 - reaching xmax? BNK Multi-Way 6 14th September 2008 10:58 PM
forum project 4932: make something that can do a good 140db at like 10hz travis Multi-Way 28 21st February 2005 03:51 AM
Ghost in the house??? bowdown Solid State 12 16th November 2004 01:08 AM
Reaching for the "highs" in a speaker WildWest Multi-Way 2 23rd May 2001 09:00 PM
Copyright ©1999-2017 diyAudio
