I took an 8 ohm speaker (in cab) and measured the voltage from a mic & op amp circuit @1m. Now, I placed a second identical speaker next to the first and connected it in parallel so the amp is outputting double the power (4 ohm total load). The output from the measuring circuit has nearly doubled in voltage.
With two speakers, the sound pressure level has doubled which means +6db over the single 8ohm speaker. 2x of the voltage reading would seem to indicate a +3db increase. To my ears, there was a significant increase in sound. Okay, so what am I missing? |
#2 |
Your thinking of dB in power terms your result does show a 6dB level increase. formula for voltage gain is 20*log10(vout/vin) therefore your doubling in voltage level is +6dB. This is because your microphone doesn't measure power but the amplitude of the sound pressure.
Decibel - Wikipedia, the free encyclopedia
CHR-70+Subs |
#3 |
John,
You're seeing a textbook increase. 3db due to double the cone area - an efficiency increase. 3db due to twice the power.
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
| Looking for a Calabrated measuring mic in Canada | mclsound | Multi-Way | 14 | 31st July 2011 02:53 AM |
| Need a Mic for basic measuring. | richard.C. | Equipment & Tools | 5 | 25th September 2010 07:54 AM |
| Soundcard and Mic for measuring. | champ222 | Multi-Way | 20 | 17th September 2010 06:46 PM |
| Speaker for Mic Measuring | Marik | Full Range | 10 | 25th February 2009 05:06 AM |
| Page generated in 0.08412 seconds (67.52% PHP - 32.48% MySQL) with 10 queries |
