Old 12th November 2011, 07:21 PM   #21
Originally Posted by tiefbassuebertr View Post
The image supplements from that one of post #1 (from the 1500 liter chamber in the attic) I have order in the meantime by the user. If I have receice, I will post it here. In this case I try to find comparable concepts by other user's by the use of follow term (keyword by google):
"IB sub in the attic"
As an example I find this:
Sub in the attic? - AVS Forum
and this both:
IB subwoofer picture gallery page 4
IB subwoofer picture gallery page 1
Are there basic articles about this kind of solutions ??
Well, if the stiffness of air behind the woofer is much less than the stiffness of the woofer suspension, then it will not affect the total stiffness. This means if the box is very big, it does not change the resonance of the woofer very much. So in a true infinite baffle, the parameters of the woofer do not change.* You will just get the response of the empty woofer. Something like an attic or the outdoors should be a true infinite baffle.*
*OK, the baffle can add some air mass load, and the walls/ceiling may not be perfectly rigid. But basically infinite baffle means if the speaker is Fs=50 at Q=0.3, then your response is Fs=50, Q=0.3. The bass response-without considering room effects-can become more like -6 dB/octave or even less.
I ask this, because I miss the actually chamber (nearly free air condition and thus no wanted 24 db high pass filter character through certainly vented box alignment).
Basiclly I don't like 12 db high pass character in this frequency aera by the possibility for realizing large chambers. Only in case of low volume chamber the closed box 12 db character (and no vented box 24 db character) is to prefer from my view.
I think you are saying:
- You never liked 24 dB vented box sound
- 12 dB sealed sound is OK only if the box size is small
- You prefer the "open" sound of infinite baffle
Is my understanding correct?
If that is so, I would say you don't need an infinite baffle all the time. Many pro drivers have a stiff suspension, and even a medium size box does not affect their response so much at room temperature.
When the pro drivers become hot, their parameters shift, and then they work in big ported boxes.
I admire you working to type the English, by the way!
Amp and eq for Precision devices PD2150... Hypex? JiiMKV Class D 4 22nd February 2011 06:24 PM
Precision Devices PD.8BM20 inrank Multi-Way 4 21st July 2010 07:53 AM
Precision devices...... Village Plank Multi-Way 10 14th December 2008 07:49 PM
Precision Devices tinitus Multi-Way 1 8th January 2008 12:57 AM
Precision devices KevinTams Subwoofers 111 22nd December 2005 02:41 PM
Copyright ©1999-2013 diyAudio
