Musical Subwoofer.... ported or sealed?
Old 3rd October 2011, 07:32 PM   #21
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by nonsuchpro View Post
I've built 3 boxes. 12x12x12, 16x12x18 and 18x12x24. (the 12" # on all 3 is the height due to desk limitations) I like the 12x12x12 best, it's only .6cf internally but it's giving me what I want for music.
Are these ported or sealed?
Old 3rd October 2011, 07:32 PM   #22
revboden is offline revboden  United States
revboden's Avatar
cool,
later
rev.
Old 3rd October 2011, 07:47 PM   #23
nonsuchpro is offline nonsuchpro  United States
nonsuchpro's Avatar
sealed
Old 3rd October 2011, 07:47 PM   #24
nonsuchpro's Avatar
Originally Posted by revboden View Post
all done or are you open to ideas.
I'm always up for suggestions... as long as it's a sealed design
Old 3rd October 2011, 07:53 PM   #25
dirkwright's Avatar
As I showed, 1 cu ft net volume, sealed, is probably the best alignment for this driver in my opinion. I'm inspired to do something like this for another system...
Old 3rd October 2011, 08:00 PM   #26
nonsuchpro's Avatar
1cu ft internal or external volume?
Old 3rd October 2011, 08:01 PM   #27
dirkwright's Avatar
It's always about net internal volume, which is minus the bracing, the driver and any plate amp you may have in there... You'll have to ask Dayton for the volume taken up by the size of the driver itself. I can't find it on the datasheet. I would avoid a cube also... try internal dimensions of 20" x 12.4" x 7.7". I assumed that all the internal stuff took up 0.1 cu ft, so total gross internal volume is 1.1 cu ft.
Old 3rd October 2011, 08:10 PM   #28
nonsuchpro's Avatar
Gotcha. Does it have to be perfect? I can use a similar drivers dimensions. I didn't do any bracing on the smaller 2 box I made. Plate amps are out of the box and in their own. http://www.diyaudio.com/forums/subwo...o-out-box.html
Old 3rd October 2011, 08:22 PM   #29
dirkwright's Avatar
In general, I believe the sealed box alignment is very forgiving. So, yeah, you can be off by a bit. Your 0.6 cu ft net is too small though. The datasheet has the dimensions on it. You can do a rough calculation from that. Consider the magnet a cylinder and the cone, well.. a cone, I guess I'd add a little for the basket also. Good luck and thanks for your enthusiasm!
Old 3rd October 2011, 08:28 PM   #30
revboden's Avatar
a 10" driver displaces about .05ft^3 and yes a sealed box is forgiving and you can always add fluff and gain about 20% volume with ~2lb per ft^3
edit: when mastering for hip-hop and the like i bring a JL car-box into the studio to do sub duty as they have nuances that a "properly" designed sub does not (delayed transient response most importantly). Having a "squashed" sub will sound right for this kind of mixing.
Musical Subwoofer.... ported or sealed?Hide this!Advertise here!
Ported vs TL vs sealed Jimmy154 Multi-Way 103 23rd August 2012 12:07 AM
Ported & sealed 2-in-1 subwoofer...possible? rocko1290 Subwoofers 11 11th September 2006 02:53 AM
sealed vs. ported sonu Multi-Way 25 9th May 2005 12:50 PM
Sealed or ported? mazeroth Subwoofers 13 23rd November 2004 12:44 PM
¿Sealed or Ported? eXn Car Audio 28 11th October 2004 11:05 PM
