Musical Subwoofer.... ported or sealed?
Old 20th September 2011, 09:23 PM   #11
chris661 is offline chris661  United Kingdom
chris661's Avatar
Originally Posted by nonsuchpro View Post
I will be using the O-Audio Bash amp with the EQ section. Can I achieve this by boosting the lows?
Hmmm...
I'm not familiar with that particular bit of kit, but a LT circuit is a very precise tool, as it matches the driver's roll-off exactly (including any resonant peak before the roll-off), which is often more than can be said for most plate amps.
It's not a particularly difficult bit of circuitry to sort out, and it sounds like it'd drop straight in to the plate amp itself, so I think I'd just go for that.
Some say that setting it for Q=0.5 is best for room integration. I support that setting, merely because it uses less gain (saves power, excursion, etc)
Chris
My work: www.grimshawaudio.com
Old 20th September 2011, 09:26 PM   #12
nonsuchpro is offline nonsuchpro  United States
nonsuchpro's Avatar
Originally Posted by chris661 View Post
Hmmm...
Chris
Well if I can figure out how to do it I'll look into it. I'm not to good with mods... heh.
Here's the amp O Audio - 500W BASH Subwoofer Amplifier
Old 3rd October 2011, 09:11 AM   #13
ODougbo is offline ODougbo  United States
Somebody on the thread said it would need a long port.
55mm x 160mm, looks on the small end, may even whistle.
Vb = 54.71 liters
Fb = 25.86 Hz
F3 = 28.39 Hz
Fill = normal
No. of Vents = 1
Vent shape = round
Vent ends = one flared
Dv = 55 mm
Lv = 160 mm
Old 3rd October 2011, 05:29 PM   #14
nonsuchpro's Avatar
Vb = 54.71 liters
Fb = 25.86 Hz
F3 = 28.39 Hz
Fill = normal
No. of Vents = 1
Vent shape = round
Dv = 55 mm
Lv = 160 mm
This is what bass box spit out... I didnt try it. I went with the red curve on the first post.
Old 3rd October 2011, 05:37 PM   #15
Sound a little wimpy, sounds like it could handle 2 - 55mm ports, but longer. I like the orange response curve.
Old 3rd October 2011, 06:08 PM   #16
KRhirschkorn is offline KRhirschkorn  United States
I my self only do Ported cabs but I tune to 30-35 Hz. and I also only use brands that I know work. some work better then others. some are just junk in any cabinet. .
Old 3rd October 2011, 06:26 PM   #17
revboden is offline revboden  United States
revboden's Avatar
all done or are you open to ideas.
Old 3rd October 2011, 07:24 PM   #18
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Hey all Beating a dead horse here I'm sure
I have a Dayton Audio RSS265HF-4 10" Reference HF Driver I'm building a box for. This driver is considered best suited for a vented box but I want to go sealed because I already have a ported (actually, passive radiated) HT Sub that is great. However, I cant stand it for music so I'm looking to build a very musical sub. Here are the different responses from ported and sealed according to BassBox. The box will be 2.5cu and I tuned the port to 30hz.
Which would you go with strictly for music playback?
Orange=Ported
Red=Sealed
Thanks!
Try 1 cu ft in a sealed box. The -3dB point is 35Hz. Nice and smooth rolloff. Group delay is less than 8ms too. Maximum output is excursion limited to about 111dB @ 270 watts.
Old 3rd October 2011, 07:27 PM   #19
dirkwright's Avatar
Here's the results, at 270watts input. Black line is FR, blue is group delay, red is excursion, and purple is phase.
Old 3rd October 2011, 07:30 PM   #20
nonsuchpro's Avatar
I've built 3 boxes. 12x12x12, 16x12x18 and 18x12x24. (the 12" # on all 3 is the height due to desk limitations) I like the 12x12x12 best, it's only .6cf internally but it's giving me what I want for music.
Musical Subwoofer.... ported or sealed?Hide this!Advertise here!
Ported vs TL vs sealed Jimmy154 Multi-Way 103 23rd August 2012 12:07 AM
Ported & sealed 2-in-1 subwoofer...possible? rocko1290 Subwoofers 11 11th September 2006 02:53 AM
sealed vs. ported sonu Multi-Way 25 9th May 2005 12:50 PM
Sealed or ported? mazeroth Subwoofers 13 23rd November 2004 12:44 PM
¿Sealed or Ported? eXn Car Audio 28 11th October 2004 11:05 PM
