Old 21st September 2011, 05:57 AM   #31
revintage's Avatar
Originally Posted by NEO Dan View Post
That's what I'm doing, I've built a few variations of my design.
Great! Give an example with the parameters above, would be exciting to see how far HR is from your IRL measured results.
Brgds
Lars
Old 21st September 2011, 06:37 AM   #32
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Below is an example of what you get in HR:
Dan
Old 21st September 2011, 06:49 AM   #33
NEO Dan's Avatar
Of course one would have had to measure the tuning to know where it actually is: ~12hz...
Dan
Old 21st September 2011, 09:22 AM   #34
revintage's Avatar
Could you publish the *.txt file from Input/Export/Hornresp Record.
Maybe I havenīt read the thread carefully enough but whats the theory behind the "BR" with ultralow resonance-frequency.
Brgds
Lars
Old 21st September 2011, 04:58 PM   #35
revintage's Avatar
Tried when I got home from work and there is no broblem to sim it in HR, albeit with a straight port. But you can also make the port and driver to work without path difference.
But maybe MJKs spreadsheets are better as one can add damping.
Brgds
Lars
Old 22nd September 2011, 08:55 AM   #36
revintage's Avatar
Hey guys,
This is what HR says about revbodens box. Placement 1,0*Pi. First with port at the front. The second with port on the rear, path difference 50cm. Third is electrical impedance. Off course no bends and a square or round port.
Brgds
Lars
Old 23rd September 2011, 09:27 AM   #37
revintage's Avatar
This is what HR shows when we make the port 43cm long, with itīs opening at the rear.
Going for a pure Onken design we get almost the same result with a 63cm port at the front and F3 at ca 20Hz.
Brgds
Lars
Old 23rd September 2011, 09:41 PM   #38
revboden's Avatar
What does the group delay at 22Hz look like between those two, 91.44cm vs 43cm.
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
slot port Q audiobahnkid592 Car Audio 5 11th January 2009 10:13 PM
HORN FOLDING Questions... screamersusa Subwoofers 4 17th November 2008 10:43 AM
Horn Folding Advice? bigmike216 Multi-Way 22 21st August 2004 10:41 AM
Slot port help Javaman Subwoofers 6 9th March 2002 07:53 PM
Page generated in 0.12887 seconds (61.49% PHP - 38.51% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
