#21 | |
frugal-phile(tm)
![]() dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#22 |
Custom Title
The answer is almost always "more". Subdivide the panels 'til they're tiny, and join your braces together wherever possible.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#23 |
OK, but that's misleading. Each one of those braces takes up a different amount of space. Therefore, the size of the panel has to change with each different brace to maintain the same net volume.
#24 |
#25 | |
frugal-phile(tm)
dave
#26 | |
Custom Title
The project was begun during the late stages of the 2008 presidential election. That's somewhat misleading though as since then I've built half a dozen subwoofers, some horns, a M-frame dipole cabinet, a preamp, 2 sets of transmission lines, some MTM 2 ways, and other bits.
#27 |
It is still misleading because the example does not state how much of the brace has been cut away, thus the rigidity of the brace is unknown. Only the thickness of the brace is shown and it is assumed to be perfectly rigid, which it is not if you are cutting big holes in it.
#28 | |
If those 3/4" braces were only 3/4" deep, then they wouldn't be that strong since wood is much stronger when in tension or compression in the direction of the grain than when it is in bending across the grain. |
#29 |
I'm with dirkwright. Working with dowels (which are hardwood) and a hunk of epoxy putty binding opposite walls (with judiciously placed wood screws to help anchor the epoxy to the walls and dowels) will stop the walls from acting like a drum head. In reverse to the cone!
I made a sealed box but instead of dowels, I used round electric conduit pipe. Light and certainly strong for this purpose. Simple, easy to replicate around the box, and as effective as you'd ever want. Planet10s resonance analysis might have some cogency here, but stopping the main big panel shakes seems more important. The design of the original post is pretty far from my intuitions about what leads to mechanical stiffness. It's binding opposite walls and triangulation that makes for stiffness; so a lot of the weighty woodwork shown is fairly unhelpful. Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB HiFi construction since 1956 |
#30 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Here is something that I'm curious no one has brought up yet...Have you already built your cube shaped enclosure?? If not yet...a cube is a big No no....especially if your going to mount your driver 'exactly in the middle of one of the panels. A cube will have backwave "pile up" of waves...all striking at the same time....tweak the size just a little so as not to make it a cube. Mount the driver slightly off-center in both axis' Think Odd numbers , not even numbers. Breaking up the distances inside will have back-waves careening around "randomly" not all in lock-step.
__________________________________________________ ______Rick.......... |
| Enough bracing? | Vikash | Multi-Way | 51 | 8th May 2006 05:58 PM |
| how much bracing is enough | gwgjr31 | Subwoofers | 1 | 5th May 2006 06:57 AM |
| bracing a floorstander | jericho_tm | Multi-Way | 8 | 5th February 2006 06:07 PM |
| Is this kind of bracing ok? | mr_push_pull | Multi-Way | 1 | 15th November 2005 02:56 PM |
| enough bracing?? | Chris8sirhC | Multi-Way | 3 | 31st January 2004 08:16 PM |
| Page generated in 0.10802 seconds (87.30% PHP - 12.70% MySQL) with 11 queries |
