I have been messing around with WinISD today I only changed a couple of things and this is what it "recommends" (I dont know if it is actually recommending this or it just randomly put something together.
I found a forum that gave me a very rough idea of what charts to look at but I cant tell whats good or whats bad. I hope I have the more necessary charts. I am planning on using this driver Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm High Fidelity Reference Series I will most likely be using the bash 300 amp but I might use the Dayton Audio SA240-B. Box 4.060 ft^3 Tuning freq. 20.16 1 vent 4in diameter 17.04in long 2 flanged ends. 1st: Trans Function Magnitude. 2nd: SPL System input 1.0W??? I noticed that changing this changes the chart so I left it at what it originally had 1.0W. 3rd: Cone excursion. 4th: Impedance. 5th: Rear port air velocity. |
#2 |
The size of the box will be fairly accurate based on the alignment i.e. closed or ported box.
The size of the port always default to 4 inches ideally for a sub the port should be approx half the diameter of the driver but this is where the design skills kick in. For example if you change the wattage so that the xmax / excursion of the driver is hitting the red max line then you will see that the port velocity has shot through the roof. In order to stop this and keep the velocity fairly low you need to use a larger diameter port. The problem with this is that it will not just have a larger diameter but the length of the port will increase drastically. Play around with the numbers and see what you get. Remember in a ported alignment your excursion will be low around the port tuning or frequency the box is designed for but it will then shoot through the roof. Also the actual box you build will be a fair bit larger than what winisd shows as this is only showing the amount of air in the box - not the thickness of wood, not the port itself and not any bracing you would but in the box. I hope this makes sense.
There are 10 types of people in the world: Those who understand binary, and those who don't... |
#3 |
The Dayton 240-B has boost at 30 hz, it's best application is for sealed designs. The boost can be defeated by soldering in a couple of different resistors, or get the Dayton 240 with doesn't have any boost.
If this is for home theater then the driver models well in 4 cu.ft. tuned to 21 hz. The Bash 300 with the default hi-pass filter would be ideal. Which version of WinISD are you using? Last edited by Mikey p; 29th August 2011 at 11:53 AM. |
#4 |
don't forget to take the room gain into account. ie the smaller the room, the more lift at lower frequencies. so that max flat Bass Reflex BR tunings have the tendencies to give boomy sound in rooms. maybe OK for some Home Theater sound effects. I tend to go for smaller BR boxes with low Fb tuning, with a sloped LF response somewhere between a sealed design and what you show. Check max SPLs and port velocity by upping power from 1W until voice coil linear (xmax) travel approaches the limit.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 29th August 2011 at 02:14 PM. |
#5 | |
Here are some numbers if you would like to take a look at it. At 300W Air port velocity. 69.2 ft/s at 10hz 21.3 ft/s at 18hz 100 ft/s at 22hz At 300W Cone excursion. The max mark is at .56in 1.576 in at 10hz .56in at 17.5hz and everything else is below .56in |
#6 | |
This is for my computer but I also play all my movies through my computer. I would say %75 music %20 movies %5 games. I don't care what the games sound like though. 21hz seems kind of low. Dont most people have it tuned in at 28-33ish? |
#7 |
#8 | |
#9 |
What is the transfer function magnitude? I changed the port size/length and well...
Air velocity peaks at 66ft/s Tuning freq 29hz Vent diameter 6in Vent length 17in -3db 24hz |
#10 |
| impedance v freq. charts | farmerjack61 | Multi-Way | 8 | 13th April 2011 08:39 PM |
| Excel charts (graphs) | johngalt47 | Everything Else | 3 | 28th March 2007 10:46 AM |
| equations for FR charts | Dave Jones | Multi-Way | 4 | 24th December 2003 09:40 PM |
| Page generated in 0.13448 seconds (85.55% PHP - 14.45% MySQL) with 11 queries |
