box for Peerless 830515
Old 27th August 2011, 06:02 PM   #1
mitch1992 is offline mitch1992  Australia
Default box for Peerless 830515
ok as you see in the title i have the peerless 830515 12inch car subwoofer driver. i plan on using it for HT use. now i have been playing around with winisd and have come up with a 86.14 ltr vented box and tuned to 28.2hz. this is my first build ever and this is only my first real estimate at what im going to build. ill upload pics and links. basically if anyone out there can reply and tell me if ive done it right and if not could you tell me how to do it right. im a total noob at speaker box building. so hopefully i wont get to many lectures . anyways i hope to get some reply's. thankyou
many regards mitch
Speaker driver
Old 27th August 2011, 06:39 PM   #2
revboden is offline revboden  United States
revboden's Avatar
As long as you don't use more than 100w that should be fine. The chuff limit on that port is 11 m/s. at 25hz. with a 6.5mm radius flair. 25mm flair moves the chuff limit up to 15m/s and 180w rms. you will need a high pass filter on the sub amp set to 20hz.
if you need more things to tinker with go here: http://www.subwoofer-builder.com/design/index.htm
get 'Flair-it' and 'Boxnotes'.
Old 28th August 2011, 04:03 AM   #3
so my box that i calculated is good? the only prob is my port size? should i make the port bigger? and if you had my sub what box would you build to get the best SQ to SPL ratio. your replies will be greatly appreciated
Old 28th August 2011, 04:13 AM   #4
also i would like to make the box with 2 ports. could you tell me how big and how long the ports should be?
box for Peerless 830515Hide this!Advertise here!
Peerless 830875 in sealed box ramiro77 Multi-Way 55 14th January 2011 01:52 PM
Peerless XLS P830452 in a small box mikee55 Car Audio 0 2nd May 2010 05:27 PM
peerless 830515 home use - ideas plaketokofths Subwoofers 2 2nd June 2007 03:40 AM
box/crossover for Peerless 8" (831709) rfdt Multi-Way 1 20th May 2005 11:34 PM
Closed box sub with Peerless XLS m127 Subwoofers 74 19th January 2005 06:58 AM
