Need advice on subwoofer/enclosure and winISD
Old 26th August 2011, 09:13 PM   #1
ahl395 is offline ahl395  United States
ahl395's Avatar
Default Need advice on subwoofer/enclosure and winISD
Hi everyone
Backstory (Optional to read ):
I used this site to build my first subwoofer last November. Very helpful as I knew nothing then, I've learned a bit more from then to now though
I built my subwoofer as I was suggested by helpful people here, but I made one big mistake when making it. It is in a vented enclosure and instead of putting the port 6" away from the sidewall like told, I accidently put it practically right next to the sidewall. It still sounds great, but when turned up loud I can hear a bit of port turbulence and it distorts, when it was designed not to distort until ~113 db.
Question:
Anyway, long story short I am now thinking of putting it in a new , properly designed enclosure. I'm also thinking of using a sealed enclosure this time. Because sometimes the bass does sound a little muddy coming from my sub, it should be more accurate and less muddy. As far as i know between the different types of enclosures though, it will restrict the sub's excursion and lower-frequency bass output. I dont usually even turn the amp volume up more than half way though and its very loud, so would it be ok? Any advice on the two types of enclosures?
If I'm going to build a sealed enclosure I need a new design i presume vs. ported. Could someone make me one in winISD? I tried to but I can never get the program to work correctly, and it gives me crazy frequency output graphs. Thanks in advance
If I'm going to stick with ported, I will keep the same design i have already, and just put the port in the correct spot
What do you think for the enclosure type?
Info on my sub and current enclosure:
Sub: Dayton SD315-88 12" Shielded DVC Subwoofer
Hooked up in Parallel
Specs:
Power Handling: 120 watts RMS/180 watts max
VCdia: 2"
Le: 1.31 mH
Impedance: 8 ohms per coil / 4 ohms total
Re: 3.0 ohms
Frequency range: 25-1,000 Hz
Fs: 27 Hz
SPL: 93.5 dB 2.83V/1m, 90.5 dB 1W/1m
Vas: 4.34 cu. ft.
Qms: 3.44
Qes: 0.38
Qts: 0.34
Xmax: 7 mm
Enclosure:
~3.4 cu. ft. 3/4in MDF
4 5/16" Port tube
19" x 19" x 20"
Amp: 115W Foster Amp
Old 26th August 2011, 11:40 PM   #2
revboden is offline revboden  United States
revboden's Avatar
I have one of those drivers, 3.4ft^3 sealed sims well, just plug the port to see if you like it. I use Oatey test plugs. 4 in. Mechanical Plastic Test Plug-33403 at The Home Depot
Old 27th August 2011, 12:49 AM   #3
Richard Ellis is online now Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Sealing up your ported enclosure, according to my figures I get Appx. a system Q of .51... Right at the system "Perfect Transient" figure. Trying to get the Qtc up toward the .707 you could 'Fill in' the port, trying to get the enclosure exist with less volume..........but it might really not be worth the effort. Seal it up, it should sound nice & tight as this driver really shouldn't be of a ported type.........the EBP is running at 71......which is of the sealed type. Now if the EBP was nearer to 100.............that would best be a ported type.
__________________________________________________ ____Rick.........
Old 27th August 2011, 01:59 AM   #4
ahl395's Avatar
Would the 4" plug fit the 4 5/16" hole, being 5/16" bigger it might not be a tight fit?
interesting, ok. I didnt think plugging the port was really an option
Dayton markets it as versatile for use in sealed or ported, and ported is how the member on here designed it.
But I would be interested in hearing it sealed. It doesnt sound BAD ported like now, just distorts when turned up really loud.
Old 27th August 2011, 08:32 AM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
With a Qts of 0.34, I'd say it's suited for vented.
If a sealed cabinet is desired, eq will probably be needed for acceptable bass response.
Chris
Old 27th August 2011, 08:48 AM   #6
ahl395's Avatar
Chris
I have an EQ for my stereo as a whole but not just the sub.
With the plugging idea I can at least try it, and then if I dont like how it sounds i can take it out, which is good. If i seal it and it sounds fine ill be good, if not then ill need to rebuild a ported enclosure.
Would this one work?
Cherne Industries 271543 Pipe Plug, Mechanical, Size 4 In
Old 27th August 2011, 06:44 PM   #7
revboden's Avatar
a sock and some duct tape will do the trick as well.
Old 28th August 2011, 06:00 PM   #8
ahl395's Avatar
true
Need advice on subwoofer/enclosure and winISDHide this!Advertise here!
Subwoofer enclosure Non-parallel enclosure to reduce standing waves qguy Subwoofers 4 4th July 2011 09:35 PM
Lab12 in a ported enclosure - WinISD toshiba_nz Multi-Way 10 26th January 2008 07:26 PM
WinISD pro to simulate 6th order bandpass subwoofer christophorus Subwoofers 14 13th September 2006 12:58 PM
Help with WinISD- building a subwoofer Xicarius Subwoofers 13 7th August 2005 01:17 AM
WinISD enclosure design program SubNut Multi-Way 3 24th September 2001 09:24 PM
Copyright ©1999-2017 diyAudio
