Old 26th August 2011, 07:09 PM   #1
ßart West-VL.'s Avatar
Question Which type carries bass furthest?
Walking around the house I noticed that the bass from my small bandpass sub (deathbox 10" from Decware) diminishes fast as I walk away, especially when I'm going to another room and outside it's barely noticeable.
Is this dependent on the type of sub or size driver in it or is it always like this, no matter what, because of the distance for example?
Bart
Old 26th August 2011, 07:46 PM   #2
JoeDJ is offline JoeDJ  United States
It a property of room acustics and sub placement.
Old 26th August 2011, 09:18 PM   #3
bear's Avatar
could be a benefit in an apartment or similar situation!?!?
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 27th August 2011, 07:38 PM   #4
Overcoming barriers is mostly a matter of how low and how loud it is. In free air, how far it carries is a matter of its wavefront shape and dispersion pattern. Inside a house and between rooms it has a lot to do with the acoustical shapes and paths presented.
Old 28th August 2011, 06:14 AM   #5
What do you mean with wavefront shape and dispersion pattern? I don't see this changing if the enclosure changes.
So it doesn't matter what kind of enclosure I use, it will always fade fast with the distance?
Still, iirc, bass from a big box with a big driver seems to have less trouble carrying the signal further then my small bandpass box.
Bart
Old 28th August 2011, 03:09 PM   #6
lower frequencies will travel around more corners and be absorbed less by stuff in the way... perhaps your big sealed box is producing lower frequencies than the bandpass?
Old 28th August 2011, 07:35 PM   #7
That sounds plausible, my small bandpass struggles to churn out some sub-40hz tunes. Thanks.
Bart
Old 28th August 2011, 08:42 PM   #8
In answer to the thread title...
mike - www.keepingsundayspecial.org
Old 29th August 2011, 04:59 PM   #9
LOL, good one.
There's even a fire extinguisher at hand, haha.
But I do believe a horn is the ultimate bass producer, if built large enough.
Just too bad most homes are too small to house them.
Bart
Old 30th August 2011, 05:53 PM   #10
A 10" woofer will create a hemisphere of pressure with a 10" diameter. A 15" woofer will create a hemisphere with a 15" diameter. A these "balls" of pressure expand, at 20' (for example) the pressure of the 10" driver's wavefront will have been divided more times to cover the increased area than the 15"s, so yes, the falloff of a smaller driver at distance is greater.
which type of woofer is the best for bass respond space2000 Multi-Way 2 27th May 2008 10:55 PM
Furthest Radio Station Recieved by Guitar davidallancole Music 1 15th August 2007 06:06 PM
Page generated in 0.09281 seconds (77.40% PHP - 22.60% MySQL) with 11 queries
