Ok I decided not to build my own woofer.
I am looking at some pre built stuff. I want it to be low and loud... as possible... BIC Formula F-12 12" Subwoofer 475 Watts 150 watts RMS/475 watts peak Dayton SUB-120 12" 150 Watt Powered Subwoofer 150 watt amp (ia that the rms or peak?) BIC Venturi V1220 12" Powered Subwoofer 200W 200 watts RMS/430 watts peak If you have any suggestions on what you would get I want something that has a frequency response of at least 25 hz. I don't really know how the size of the driver and its wattage compare... On the last one even though the peak is lower its rms is higher. I would assume that would be the better choice o.O? Maybe even brands differ I don't know... Like AMD and Intell processors. Last edited by spellwords; 26th August 2011 at 06:06 PM. |
#2 |
I've had a few BIC subs (don't recall models) but they were very similar to the ones you linked and I couldn't stand them. Sloppy, bloated bass that was just horrible no matter where I put it or what I tried. I suspect the Dayton would be a better choice and I'd buy that one over any BIC but that is nothing more than a guess really and purely going off my dislike for the BIC product. But it does come from experience with them
#3 | |
That is why I am asking lol |
#4 |
Yes I know lol
#5 |
Is Pyle a decent brand?
#6 |
What's your budget range? Are you able to build a cabinet (I know you said you weren't going that route)? You could do a bit better by purchasing a plate amp (the amp on the back of the box) and a speaker of your choice and simply build your own box. You will most likely be happier with the results and it will have the DIY factor
I don't have any personal experience with Pyle but I bet another member will chime in soon...... |
#7 | |
Could I use a car woofer with a plate amp? What would I need to do different? |
#8 |
You could do that.....be careful of the ohm rating and what the plate amp will do.....if you have a 4ohm woofer and your amp will only drive 8ohms then there is a problem but there is also ways around that. What sub do you have and maybe we can come up with an amp that will work well?
I suspect most plate amps are good to 4ohms or maybe even lower so this shouldn't be an issue....... |
#9 | |
Power output: 170 watts RMS @ 8 ohms 240 watts RMS @ 4 ohms Lets just say I had that amp and I bought a driver that was 900 watts RMS 1,800 watts peak. Would that even work? Would it sound like junk? Doe sit have to be 240 watt rms for it to work? Last edited by spellwords; 26th August 2011 at 08:39 PM. |
#10 |
That looks like a nice amp with plenty of power. I have had a few Dayton products and they have never let me down.
Not too mention Parts Express is top notch!! |
| laser pick-up | bebo60 | Digital Source | 13 | 31st August 2011 07:30 AM |
| Help me pick a DAC | kuroguy | Digital Source | 5 | 28th January 2008 08:40 PM |
| Which cap would you pick? | davidallancole | Parts | 11 | 7th December 2007 02:51 AM |
| Page generated in 0.11787 seconds (83.53% PHP - 16.47% MySQL) with 10 queries |
