#11 |
I've found one the rss315ho-4 works in a 70l sealed cab with parametric eq fc=25hz, Q1.00,gain 5db. with 100w should work well to 104db. f3 = 28hz
http://www.parts-express.com/pe/show...number=295-466 |
#12 | |
One solution is to just go for a bigger driver, preferably one with a higher force factor (Bl) and a lower Q. There are plenty of suitable 12''ers at the Parts Express site you mention, and prices are reasonable. You cannot have bass unless you move air volume and in this respect a bigger, stronger guy (woofer) will always be better suited. The other two solutions were already proposed to you: either an LT, which will "cost" you amplifier power and extra displacement (ie increased distortion with increased loudness), or a reflex, which will save you power and displacement, but will cost you in time smearing and possible room mode excitation. Make sure to check amplifier requirements if you choose LT. If you find that you will run out of current, you may be better off choosing an 8 Ohm, or even a 16 Ohm woofer, although the latter are harder to come by. I avoid reflex alignments, but one rough way to get a reasonably well-damped one is to model a box as big as a woofer's Vas (45 l in your case), and then add a port that tunes to the system's new resonance frequency. If I calculated this correctly -and I did it very roughly with pencil and paper- this will get you flattish down to around 36 Hz. If this frequency does not coincide with a major room mode, it's an option you can consider with a goodly chance of success. Last edited by bbggg; 24th August 2011 at 12:04 AM. |
#13 |
Hi all.
Thanks for some really great responses. Aren't LT and parametric eq just going to add distortion, and if i use it incorrectly, potentially damage the driver from over excursion? I had initially wanted to avoid vented systems for the risk of a "blowy" boom, and honestly i'd rather have no bass than rubbish bass. However, i've just heard a pair of Definitive Technology Mythos floorstanders. They use a small active sub, and 2 passive radiators. The response was UNBELIEVABLE from such a small system. Should i bother investigating passive radiators? Not many people seem to use them? Last edited by christof123; 24th August 2011 at 04:06 PM. |
#14 |
The answer is no, as long as you know what you 're doing. If you use electricity incorrectly, you may electrocute yourself, and if you use water incorrectly, you may drown. Such is life, alas.
#15 | |
There are downsides with PRs though. Cost being a main concern, it is a ported alignment so a piece of PVC is much cheaper! You'll need two passive radiators, one on either side of the box to prevent transferring vibration to the flood so cost/complexity goes up. It does have a phase shift at the tuned frequency but mine is so low I don't notice. The cut off below tuning is really steep--around 24dB per octave so if tuned high--best to use a high pass filter. During music, my 21 Hz tuned PR does not move so it acts more like a sealed box. No bass blowing through a port to muddy up the sound. Some people describe the "PR sound" as a hybrid between a sealed box and ported. Pretty close I would say, no sound coming from a port like a sealed box but a physical resonator for the ported punch around the tuned frequency. The main downside of the PR is once you do it--you're stuck with it! Chopping additional holes in a box is rather permanent unless you don't mind making new boxes. Since I've always liked the Polk Audio SDA SRS/Klipsch and Definitive PR sound, it is not an issue. If you don't, then that alignment is not for you. If you don't like a box with a bunch of active/drone drivers and attempting to explain to people how it works--stay away from PR! |
#16 | |
I do doubt that a single 6x10" driver could hit 14Hz (cone area is ~equal to an 8"), even at -10dB. Be wary of following commercial designs with active crossover stuff, as they can be very complex in order to get the most out of limited cone area. |
#17 |
If your budget can take it, a little DSP seems perfect for this task.
You can EQ the response to add a little low end, plus take care of room modes with something like this: MiniDSP kit | miniDSP I have used similar devices and been very happy with the extra extension and removal of boom... herm |
| Ribbon Low-End Response | rockguitardude | Planars & Exotics | 14 | 11th July 2011 06:38 PM |
| Undivided Sealed Enclosure Response With Multiple Drivers... | HsOffRoad | Subwoofers | 5 | 7th October 2007 02:59 PM |
| Transient Response: Sealed v Dipole | rick57 | Multi-Way | 4 | 12th December 2006 05:26 AM |
| Ouput relay vs low end response | d3imlay | Solid State | 3 | 11th December 2006 07:24 AM |
| high end version of low end phono stage | dsavitsk | Solid State | 20 | 1st September 2005 11:51 PM |
