I have a Cetec Gauss #4883B 18" driver. I can't find any specifications that will help me build an enclosure that this driver will like to operate in, so I can use it as a sub-woofer with my portable P.A. equipment.
#2 |
fyi
Brand Gauss Model 4883 B Nom. diamerer [inch] 18 Vas [Liters] 538.1 Qts 0.3391 Qes 0.39 Qms 2.6 Fs [Hz] 23 Sensitivity [dB] 94 Max Power [W] 400 xmax [mm] 15 Moving mass [g] 176.42 Disp area [m2] 0.119 Re [ohm] 5.3 Z [ohm] 8 L [mH] 1 Bl [Tm] 18.613 this one wil play really low. what type of cab are u planning to bild?
one good thing about music ,when it hit you feel no pain. so hit me with music. |
#3 |
I would like to build a "scoop" style enclosure or maybe a folded horn. I have read that this driver being an older design, can be a little picky about how it is used. I have had this speaker in storage for over 20yrs. and just a couple of months ago I had it reconed. I have never used it. Only reconed it because I kept up with it all those years, and I guess I wanted to see something for the effort. I bought 6 of them in the summer of 1989, sold 2 that day. Sometime after that 3 of them were stolen, I kind of got discouraged and lose interest.
#4 |
#5 | |
b |
#6 |
i have a 4883A ...... can anyone tell me the specs of this one, or is there not much difference with the 'B' version...?
thank you |
#7 | |
X = 69 Vas = 610liters Qts = 0.2777 Fs = 22hz Sens = 95db Pe = 400watts Xmax = 6.3mm The Xmax figure EPA gave for the 4883B does not seem possible, sounds like 15mm Xmech was put in instead of Xmax. 6.3 Xmax was big back in those days, an EV 18B only had 3.3mm Xmax for instance. Generally the difference between "A" or "B" models are differences in cone, surround, or spiders. Are you certain your driver has an "A" rather than "B" kit? |
#8 |
thanks for suplying the specs, for shure it's a A model. I finely have the time to put it in WinISD....
let's go...! |
#9 |
mmmmmm, maybe i dont have enough details about this speaker.....the plot comes out as a perfect driver-cabinet combination.......?????
i guess i need to know more then weltersys was ably to supply me (but thanks anyways.....!) Anyone ? Cheers |
#10 |
| FS: Gauss 4583F 15" woofers | doucanoe | Swap Meet | 1 | 28th May 2010 08:39 PM |
| cetec gauss | allyourzigg | Multi-Way | 6 | 28th June 2007 09:18 AM |
| Gauss 3288 12" Co-axial Speakers | snoopyma | Multi-Way | 5 | 28th November 2004 03:07 PM |
| EAW 18" driver specs | Graydon | Subwoofers | 26 | 7th November 2004 02:43 PM |
| Page generated in 0.10875 seconds (76.79% PHP - 23.21% MySQL) with 11 queries |
