#91 |
Greets!
Using Sd, Mms, Fs and HornResp's p0 = 1.205 Kg/m^3, c = 344 m/sec; I calculate ~7.9615 L. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#92 |
in the same time LOL , guy i saw the video last year on china website. i like pmc tl before. i did upload on my profile. they did contest the china singer long time ago but many singers in the contest place. they have many single alblum at the moment. see for relaxation guys
#93 | |
regards |
#94 |
#95 |
#96 |
the cabs work well. but my friends want the narrow in the dimension. i try the new tha f narrow dm. but still not finish to build. i have the video from original plan. 4 cabs in a stack per side.
THA F Horn V.1 played in wedding Party - YouTube
#97 | |
So I guess it was Tong Li in one of her early performances . Btw, I used the older MB series for years for mastering purposes. Keep on the good work!
#98 | |
Back in the mid 1980s I designed a cabinet very similar to your design, with two or four 15" per box, called the L2 and L4. Just ran the design through Hornresp to see what they actually could do with the power we had back then, it ran out of Xmax at about 245 watts per cone, which is about what the Crest 8001 amps could deliver. The L4 tuning (about 45Hz) was lower than your box, but they kicked like crazy considering the low power and short Xmax (6.4mm) of the speakers used. We had 28 L4 cabinets, though the most we used at once was 20. Be sure to use a HP just below your box tuning, or the speakers may develop some holes if you play anything loud and low .
#99 |
You're welcome!
Use multiple drivers to increase Vas enough to calculate a decent size TH. GM
#100 | |
![]() Meng Jiang Nan - ????? - YouTube Meng Jiang Nan - wang xinya - YouTube |
| New Compact TL Project | MJL21193 | Multi-Way | 80 | 15th June 2009 11:25 PM |
| Help with TL Project | Zoomer | Multi-Way | 0 | 18th February 2008 10:05 PM |
| Horn + TL Project combined | Sky_Knight | Full Range | 12 | 20th December 2006 10:06 PM |
| Will these work in a TL project? | JimW | Multi-Way | 4 | 15th February 2006 12:42 PM |
| MTM TL Project | bostonflyer | Multi-Way | 5 | 12th October 2005 07:42 AM |
