Old 17th August 2011, 09:03 PM   #1
Default Wiring 2ohm sub in stereo mode
I have a subwoofer which reads out 2.7ohms, I hooked it up bridged to a 4 channel amp and the amp goes into protect mode, so I looked at the amp's documentation, which states the impedance goes 4-8ohms in bridged mode and 2-4ohms in stereo mode. How can I hook it up in stereo mode?
Old 17th August 2011, 09:07 PM   #2
kevinkr's Avatar
Does the woofer have dual voice coils or just a single VC?
If only a single VC you will only be able to use a single channel of that amplifier as it appears that the VC impedance may be significantly lower than 4 ohms..
www.kta-hifi.net
Old 17th August 2011, 09:30 PM   #3
It's DVC, but I wired it parallel inside the coil, because It's a subwoofer that I rebuilt, and the original was a SVC.
Old 17th August 2011, 10:40 PM   #4
Could you explain what you mean by "I wired it parallel inside the coil" ?
Mike
Old 17th August 2011, 10:59 PM   #5
Well, what I did was take the DVC coil, and solder the two positives together, and the two negatives together, then I soldered the positives to the positive terminal, and the negatives to the negative terminals, this gave me about 2ohms, which is what I wanted, because I thought I could run the amp bridged to this single sub, but whenever I hook it up and put up the volume the amp goes into protect mode, and if I run the sub on only one channel it sounds very low, I doubled up on the spider, and I wonder if this could be why it sounds so low? My amp only throws out 75 watts per channel.
Old 18th August 2011, 12:53 AM   #6
OK, I'm still not clear on what you did. Did you modify the speaker drivers' voice coil wiring, or are you saying you wired the terminals together? To do it properly you need to connect each voice coil separately to each of the amplifier outputs, that way you won't overload the amp.
Mike
Old 18th August 2011, 12:57 AM   #7
I wired the little coil cables positive with positive and negative with negative, and then wired that up to the terminals. Tomorrow I'll undo the coil wiring and wire each side of the coil to a different channel and see how that works, thanks.
Old 18th August 2011, 12:59 AM   #8
Seems you need to undo your paralleling of the coils so they are separate
and 4 ohms each. Your amp might be able to drive each 4 ohm coil with
2 channels bridged, (= 4 channels), if not then just drive with 2 channels.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Operating a stereo amp in bridged mode Captn Dave Tubes / Valves 10 11th July 2010 04:55 PM
LM4780 Stereo Mode Grounding daccordimark Audio Sector 3 5th March 2010 03:00 PM
stereo/mono WIRING CG_25 Instruments and Amps 23 13th August 2007 08:09 PM
PCX1250 2ohm mode Problem ctg353535 Car Audio 1 15th April 2007 02:26 AM
Wiring stereo plugs. Valerie Everything Else 1 13th November 2003 05:59 AM
Page generated in 0.08694 seconds (77.88% PHP - 22.12% MySQL) with 10 queries
