do we need to consider vehicle dimensions for car subwoofer?
Old 16th August 2011, 05:30 PM   #1
60ndown is offline 60ndown  United States
Default do we need to consider vehicle dimensions for car subwoofer?
ive seen people say that allowing for a vehicles internal dimensions is important when designing a subwoofer for a vehicle.
do you agree?
or does the way a subwoofer will perform in a vehicle have nothing to do with the vehicle size?
Old 16th August 2011, 06:12 PM   #2
johnr66 is offline johnr66  United States
Yes, for if the subwoofer is too big, it will not fit in the vehicle
I find the position of the speaker in the vehicle makes a huge difference. Placing the speaker more towards the rear enhances the lower bass. Placing the speaker more forward, say behind the front seats looses the punch. This made the most difference. Vehicle size does have some effect, but position is more important.
Old 16th August 2011, 08:55 PM   #3
weltersys is offline weltersys  United States
weltersys's Avatar
do you agree?
Differing internal dimensions will cause dips and peaks in response at different frequencies.
Smaller interiors will have more "cabin gain", more very low bass compared to upper bass. A rolled off low end as a sealed speaker will have may end up with (near) flat response in a small vehicle, but need compensation (bass boost) in a larger vehicle.
Old 19th August 2011, 08:40 PM   #4
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Tapped Horn meets Bandpass Sub
Old 19th August 2011, 11:35 PM   #5
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
check out PWK Designs He uses his own special software to create a box tailored to a specific to the vehicle and sub used based on the dimensions, TS parameters and your desired response.
Old 22nd August 2011, 02:09 PM   #6
hooligan72 is offline hooligan72  United States
A good parametric eq, even if only one band is used for the sub, can sometimes be your best friend. It only takes a couple of minutes using a frequency sweep to identify that all vehicles have a huge peak in response at the resonant frequency of the car. Your eq can flatten that out......usually.
That being said; a lot of people actually embrace that peak and enhance it just for the boom factor. Those of us who enjoy music the way it was intended to be heard just eq out the peak.
Old 22nd August 2011, 04:41 PM   #7
1audiohack is offline 1audiohack  United States
1audiohack's Avatar
Why wouldn't you include cabin volume in the design process?
For instance an Eminence Lab12 modeled in ¼ space like you might use it in a house wants about a 2.8ft³ vented enclosure, in a 160ft³ box like an extra cab truck the same driver performs very flat from 100 down to 10 Hz in a 1.6ft³ sealed box and has better time domain performance as well. Easy to build, less space in the cab and less elecrical processing required. Sounds like a win win win to me.
Old 23rd August 2011, 12:46 AM   #8
rvrazvan is offline rvrazvan  Romania
rvrazvan's Avatar
Is it possible to have an open baffle sub in the car )?
Old 1st September 2011, 10:41 AM   #9
TheBaronGroog is offline TheBaronGroog  United Kingdom
60ndown-i'm sure you know the answer to this Xtremerevolution on diyma will model an enclosure with boundary loading for you-small fee attached.
rvrazvan-yes IB works very well in saloons, hatchbacks it's harder to seal the boot from the cabin. I have seen an E39 BMW 5er with two 15" IB mounted into the front footwells! Anything over 3x Vas can be considered IB, so provided your total "boot" volume is over 3x Vas you're hot to trot. Remember with IB that cone area is king, if you have a factory 8" hole in the rear deck you can fit a 15" under the hole and suffer little loss in output. Just remember that higher QTS subs will work best and that power handling will be approx 1/2 of the same sub in an enclosure.
do we need to consider vehicle dimensions for car subwoofer?Hide this!Advertise here!
Best speakers for my vehicle? Dustinh22 Car Audio 0 23rd June 2011 01:45 AM
Vehicle acoustics... Huricaine Subwoofers 29 7th March 2011 04:43 PM
FAST system in a vehicle 901Fixer Car Audio 0 26th November 2010 07:56 PM
Car subwoofer lejaybo Subwoofers 8 15th October 2009 02:22 AM
open baffle subwoofer "enclosure" dimensions noodle_snacks Multi-Way 4 18th July 2006 06:51 AM
Copyright ©1999-2017 diyAudio
