I am amplifier constrictor, but I dont know much about speakres and that stuff and I whant your help if somehow is possible about something.
I have 4 pieces of 15" 450W speakers and I want to build 4 bass bins for it. That speakers have good quality, and they made in my country Serbia. - Can this speaker work as bass bins? - Do you have any suggestion for speaker box? - I only have this parametars and its imposibile to get more informations about this speaker. Thanks and regards Nikola |
#2 |
Well it is listed as a full range driver not a subwoofer....and no xmax listed either?
#3 |
No, only this parametars on the picture
#4 |
It looks more like a mid-bass due to the high efficiency and low-ish cone mass
JEREMY M_________________________________ I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ? |
#5 | |
#6 |
Yes its mid/bass speaker. I dont know Re, nobady know, I asked lot of people who worked with this spekar but Xmax is around 4mm. My version is V8 with 8ohm
This is 2way spekar with this bass. Maybe can help his dimensions |
#7 |
Measure the voice coil of the driver with an ohm meter to find Re.
Vas is good so the enclosure won't be too big, it would be good to know Qes but assuming it's similar to Qts and with ha fairly low Fs you would be best to make a reflex design. Extension will be sacrificed mainly due to Xmax being low, effciency should be fairly good if you don't go down much lower than 50Hz. At a guess I would say 120l box tuned to 45Hz, that is only a guess! Edit - would be nice to have more parameters, Re might be a round 6.9ohm.
I thought about it once, but then thought again. Last edited by Boscoe; 16th August 2011 at 06:55 PM. |
#8 |
Yes thats corect. My calculation is 118l with tuning freq on 45Hz.
So we resolved main probelem, can anyone help me about dimensions of the box. I know to made and calculate box with bas reflex port pipe, but I want this box (like on the picture) and I dont know calculaton for slot port box, I serach on the web but I don't understand, so please help me But its important to be hight max 50cm and width max 45cm. Depth of the box is not important, ofcource inner dimension of the box Thanks and Regards Last edited by Dzony988; 17th August 2011 at 08:54 PM. |
#9 |
I would be thinking rear loaded horn or transmission line. If you could get or measure Qes and Qms you could use hornresp to model some possibilities. I bet you could get some pretty decent results down to 30Hz or so. Maybe not enough for real sound reinforcement applications in big venues but a small DJ gig maybe.
mike - www.keepingsundayspecial.org |
#10 | |
With a Qts of 0.31, Fs 40Hz and Vas of 98L I've no idea how you get to ~ 120L boxes per driver, 60L tuned to 40Hz looks good to me. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| WTB: 2x LaScala bass bins | jdubs | Swap Meet | 3 | 18th November 2011 05:54 PM |
| FS: Altec bass bins | Jimmy D. | Swap Meet | 4 | 1st November 2010 12:32 AM |
| A pair of Klipschorn Bass bins + | limono | Swap Meet | 4 | 23rd October 2009 10:10 PM |
| How to make Bass bins | Jaminator | Subwoofers | 8 | 8th November 2007 11:24 PM |
| Community GGM Bass bins | tmc | Multi-Way | 8 | 21st November 2002 09:36 PM |
| Page generated in 0.11352 seconds (79.58% PHP - 20.42% MySQL) with 11 queries |
