I would like to know the best option for wiring my subs. My mono alpine amp is 350 watts at 2ohms, and 200 watts at 4ohms. I have two subs, one is a Rockford Fosgate fast&furious dual voice coil 4ohm sub, the other is a kicker single voice coil 4ohm sub. Is there a way to wire this to get down to 2 ohms to get the full power from the sub? I'd like to not ditch the 2nd sub as I have a dual enclosure and it will be in there if its used or not. I've been trying to figure this out and just can't. Any help would be greatly appreciated.
#2 |
Wire the subs in parallel while ditching the one of the voice coils of the dual voice coil subs.
na |
#3 | |
I'd suggest wiring the Rockford Fosgate fast&furious dual voice coil 4ohm in series, then parallel it with the kicker single voice coil 4ohm sub. The difference between 350 watts at 2ohms, and 200 watts at 4ohms is less than 3 dB, doubling cone area adds 3 dB, assuming the speakers have similar phase response. Compare it to qguy's suggestion and see which produces more actual SPL, speakers have far different impedance at different frequencies, hard to say what will actually work best with your amp without testing. |
#4 | |
Bart Last edited by ßart West-VL.; 12th August 2011 at 07:41 AM. |
#5 |
Plus one.
#6 |
8//4 = 2.33
Don't any of you get taught metal arithmetic at school?
regards Andrew T. |
#7 | |
Bart |
#8 |
So I mistakenly gave the average value but it seems that even this 2.6666...7Ω load can be handled by the amp, give it a try.
Bart |
#9 |
Yes. (In the case amp+low impedance doesn't work) The other way, (6Ω) is to parallel the 2 voice coils (2Ω) in one sub and series with second woofer (4Ω).
#10 |
well caught. thanks.
regards Andrew T. |
| wiring | trai1824 | Multi-Way | 24 | 17th February 2008 11:33 PM |
| Sub Wiring | BEAN27 | Subwoofers | 19 | 6th May 2006 04:14 AM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| wiring | whiteboy | Subwoofers | 2 | 5th May 2005 09:51 PM |
| Page generated in 0.09735 seconds (82.75% PHP - 17.25% MySQL) with 10 queries |
