Who can identify these 12" drivers?
Any information is welcome Weight = 9,9Kg Diameter magnet = 21cm Basket = Alu Fs approx 50Hz Hand written stickers say: PR33LTX350 “AP 1503” Suspension au P1200 Kurt – elluellen Spider – Kurt elluellen ![]() ![]()
#2 |
Those I believe are made by Audax.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#3 |
Audio Junkie
those might be RCF pro drivers made in Italy
It's not about what you can BUY...It's about what you can BUILD! |
#4 |
@ Djim
Hi, looking at the plates on the back of the magnets, they "appear" similar to B&C and BMS drivers. Also the BMS recessed areas around the rear mounting circumference has a similar casting. These links are just for a quick comparison, & as they are new models & yours look older ones, i wouldn't expect they would look exactly identical anyway ! B&C SPEAKERS Drawing & Mounting |
#5 |
Thanks so far, RCF never used these connectors...
B&C doesn't use these these connectors either and the backplate is flat. Any ideas which Audax types? Last edited by Djim; 6th August 2011 at 06:55 PM. |
#6 | ||
@ Djim
Hope you discover what they are, let us know |
#7 |
Agreed, their pro version of the PR330 IIRC ['X' in the model #].
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 |
@ Djim
If it is an Audax, you might be able to find it in here AUDAX, LA PASSION DU HAUT-PARLEUR http://www.audax.com/archives/PR330T...gue%201994.pdf There are several PR330 models, but i don't see PR33LTX350 ? Happy hunting |
#9 |
Jep, seems 5th Element and GM are correct
,it is definitely an Audax PR330 driver.So far the PR330T4 comes most close. I guess it's something custom made Zero D cause I also can't find any info specific to the PR33LTX350. Last edited by Djim; 6th August 2011 at 08:04 PM. |
#10 |
What are you planning with these?
| Can anybody identify these vintage drivers? | Jim85IROC | Multi-Way | 3 | 15th February 2012 03:07 AM |
| Can anyone identify these drivers? | NewVintageNut | Multi-Way | 9 | 23rd January 2008 02:05 PM |
| Identify these loudspeaker drivers and more info? | Bull | Multi-Way | 0 | 13th January 2008 08:43 PM |
| Can anyone identify these drivers? | Brisso57 | Multi-Way | 0 | 12th December 2007 09:03 AM |
| Can you identify these cheap drivers? | seangoesbonk | Multi-Way | 12 | 23rd November 2002 02:21 AM |
| Page generated in 0.10958 seconds (78.71% PHP - 21.29% MySQL) with 11 queries |
