wilson audio :watch dog subwoofer drivers
Old 14th November 2011, 07:15 PM   #41
muddasirwaheedmalik is offline muddasirwaheedmalik  Pakistan
Ok all , sorry for delayed response was away out of country.
Just took up the measurements.
Fs=41 Hz !!!!!!
Qts=0.55
Qms=7.0
Qes=0.59
I put it in a sealed box of Vb=82 litre and Fb=44.5 Hz giving VAS=14.8 litres
Now 14.8 L is small Vas, the driver sensitivity around 88. WinISD gave me 1.44 cubic feet with 30 Hz tunning ??????for c4.sc4 chebyschev...for most output in 30-40 hz range which is good enough for music. for below 30 Hz i have to go extended bass shelf. ??
BUT the wison watch dog is actually around 4.8 cubic feet external. with bracing, port and separate box for amp i expect it to be around 3 cu feet or around 140 L. BUT winISD gave me 1.44 cubic feet ??? with 4,6 inch tube going 32 inch long ????
HELP HERE please
Old 14th November 2011, 07:21 PM   #42
badman is offline badman  United States
badman's Avatar
You want the Fs to double, so shrink that box down much smaller, if you want a meaningful Vas measurement. That said, it does seem like a tiny Vas.
Fs=41 Hz !!!!!!
Qts=0.55
Qms=7.0
Qes=0.59
HELP HERE please
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 14th November 2011, 07:23 PM   #43
no i never said i wanted Fs to double ??? i wanted it to be low but i cannot understand how there is so much discrepancy in box volume.
Old 14th November 2011, 07:26 PM   #44
badman's Avatar
To get an accurate Vas measurement, you want the Fb to be double or more times Fs. Your test box is too big to get a good grip on the Vas.
Old 14th November 2011, 07:39 PM   #45
Ok i got the point, then i think the vas calculation is wrong. can i use weight method. any brief link please. would 100 g do.
Old 15th November 2011, 03:48 PM   #46
tb46 is offline tb46  United States
Default Link for T/S parameter measurement:
Measuring Loudspeaker Driver Parameters
Oliver
wilson audio :watch dog subwoofer driversHide this!Advertise here!
Wilson Audio Watt/Puppy8 drivers& acesories elviukai Swap Meet 0 29th July 2009 08:31 PM
Wilson WITT Series I Drivers dritter_1999 Full Range 0 5th April 2006 06:20 PM
wilson sophia drivers? joz Multi-Way 2 26th November 2002 08:42 PM
Replacement drivers for Wilson WATT 3 sfdoddsy Multi-Way 0 24th September 2002 12:23 AM
