So, I have a pair of satellite speakers that have a sensitivity of about 94dB. I'm having trouble picking a subwoofer driver to go with them. This will be a self powered subwoofer with a plate amp. Do I choose a driver that is less, the same, or more sensitive than what I've got? If I choose a driver that is a lot less sensitive, won't the increased gain required to match the satellites cause a lot of distortion in the sub (I'm assuming the driver has the required power capacity)? If I use one that is more sensitive, how do I pad it down to match if it has it's own amp (maybe that's not a problem)?
It seems that all the subwoofers that go really low have very low sensitivity, which is a problem also, since the gain would have to be so high that I assume they'd have a lot of distortion. I'm intending to build just a regular vented type of box for this. |
#2 |
frugal-phile(tm)
Since the woofer has its own amp, you aren't really concerned with its sensitivity wrt the satelittes.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |
Assuming the driver can handle the extra power, doesn't the distortion go up with greater cone displacement? Don't we want low distortion subwoofers, since we can hear all of the harmonics? |
#4 |
the sensitivity figures is just one part of three things you need to know. You figure out how much dynamic range you want then use the sensitivity to figure out how much power you need achieve that range.
example: 1w to your mains gives you 94db output. If you get a sub that has a sensitivity of 87db 1w/1m you need 6.6w going to the sub for it to match (94db). if you want 12db headroom over 94db the sub would need to handle 105.6w and a amp to supply that power. the mains would need 32w to hit the target 12db headroom (106db). |
#5 |
distortion goes up if you exceed xmax, as long as you stay within the ratings of a driver the distortion is minimized.
#6 | |
So, let's say I screw up and I make a sub that has 98 dB sensitivity and it's own amp. What do I do then? |
#7 |
#8 | |
You figure out... "hummm, how loud do i want this to go..." that's it. you're going to build your own driver? just kidding the system dosent have a sensitivity rating, just the driver. You match the driver with the amp and use design to make sure the driver and amp work together to make the type of sound you want plus about two dozen other things to consider with box design. |
#9 |
you might want to start here: WinISD Pro Tutorial and Download (A detailed guide on how to use WinISD Pro) - Home Theater Forum and Systems - HomeTheaterShack.com
or here: http://gonecatfishin.net/WINISD.htm Last edited by revboden; 30th July 2011 at 11:16 PM. |
#10 | |
| Compression driver sensitivity | Sanon | Multi-Way | 32 | 24th July 2011 01:14 PM |
| Q Re; driver sensitivity? | Jonathan Bright | Multi-Way | 6 | 17th May 2011 12:47 AM |
| driver sensitivity vs system sensitivity | bvan | Full Range | 12 | 5th November 2007 07:57 PM |
| Multiple driver sensitivity gain? | woody | Multi-Way | 3 | 12th February 2004 03:24 PM |
| driver sensitivity | griff | Multi-Way | 10 | 31st January 2002 08:32 PM |
| Page generated in 0.11657 seconds (79.88% PHP - 20.12% MySQL) with 11 queries |
