The Othorn tapped horn
Old 15th July 2018, 12:08 PM   #461
Alexlel is online now Alexlel  France
Originally Posted by Djim View Post
In other words, the 18HP1030 has more Xmax but has a weaker motor compared to the 18NW100. I wouldn't be so sure if the 18HP1030 is a good choice for a difficult load like the Othorn…
Hi !
Thanks for those informations, I'm learning a bit every day
I would love to give a try to the speaker, just to see what we can get from it, it would one of the cheapest suitable driver for the Othorn if it was able to survive and if the motor has enough power (I imagine we can't really know without a real try ?).
Otherwise I'm gonna watch out the Oberton 18XB1500.
- 310€ (+50€ compared to the FaitalPRO 18HP1030-4)
- 11mm xmax / 7.5mm
- 126dB@30hz@600W
- 188.9 N*s/m / 161.2 N*s/m loaded
Quite close to the 18sw115 but 80€ cheaper for the price of a lower Xmax and a bit less SPL output.
Those 80€ are definitly not negligible when you have to get 2.
FaitalPRO 18HP1030 would be the better solution if it could handle the Othorn but if it can't I will head on to the Oberton 18XB1500.
The Othorn tapped hornHide this!Advertise here!
Help with a tapped horn. mike james 533 Subwoofers 33 4th January 2013 11:25 AM
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
