The Othorn tapped horn
Old 8th February 2018, 01:38 AM   #431
geritass is offline geritass  Mexico
Originally Posted by MemX View Post
Please start a new thread to ask your question - this thread is for discussion on the Othorn only.
Sorry, my mistake, thxs
Old 14th May 2018, 08:28 PM   #432
Bomasz is offline Bomasz
@Josh I would like to ask for the files regarding this project, and what kind of wood thickness it is made for ?
EDIT: found files at: Ricci's Gjallarhorn & Othorn Files - Bass Projects - Data-Bass Forums but you need to register to download
Old 15th May 2018, 04:17 PM   #433
Josh Ricci is offline Josh Ricci  United States
Yes if you want to download the files you will have to register.
Old 15th May 2018, 06:01 PM   #434
Thank you for your respond, what kind of mid-top do you think will be suited to pair with your design? Maybe do you have some your project ? I was thinking SMT212 and crossover point at 100Hz
Old 16th May 2018, 11:58 AM   #435
Or X-Tro, with X point at 90hz, keeping the horn concept, but I’ll mainly be playing dub, so I don’t need a hard kick
Old 20th June 2018, 07:20 AM   #436
Infinite Audio NZ is offline Infinite Audio NZ  New Zealand
Well, the 8 Othorns are opening up nicely, and I am (as are the rest of the crew) simply in love with this design. We initially experienced an overheating issue on their first outing, which we have since ironed out I believe. Apart from that one little glitch, we couldn't be happier. They are purring along perfectly.
My friend did float the idea of water cooling the magnets. Has anyone tried this on sub drivers (neodymium in particular) or know of anyone that has?
For everyone who messaged me or replied in this thread, regarding data and RTS readings etc, when I get back to NZ in October, I will finally have the equipment to perform specific tests, and will post them in due course.
For now though, we are looking at options for diy tops for the coming summer festival season, which will replace the cloned F1 Res2's we purchased for the interim. Been musing over many ideas, from the simplicity of the MT121/130 and SMT212, to the details curves of the PM90. So many decisions, with such limited experiences with the Othorns....
For now, here's 4 x Othorns getting a soaking in the NZ bush. Thankfully someone had some umbrella's handy
Be well people!
Old 20th June 2018, 09:15 AM   #437
chrapladm is offline chrapladm  Australia
What are you wanting out of a top?
If using full active setup I know a few designs that are crazy on SPL but not exactly cheap. Eitherway nice to see the Othorns are continuing to populate the world.
Old 20th June 2018, 09:27 AM   #438
Hey mate
I made a thread over in the multi forum, which details most particulars, wants and needs. Perhaps you could check it out if you've got the time
DIY tops for Othorn/ES18 stack?
And yes, more Othorn = more happy population I feel
Old 20th June 2018, 03:07 PM   #439
USRFobiwan is offline USRFobiwan
Horn Addict
USRFobiwan's Avatar
May i asked what you did for overheating issues? and do you know what caused the overheating?
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
Old 20th June 2018, 03:27 PM   #440
We believed it was caused by some kind soul, who thought it would be a good idea to pin trippy lycra fabric to the speakers, covering the port holes. Sure it looked amazing, but he was effectively blocking a Mack trucks worth of air pressure from escaping.
Unfortunately this is a true story, and happened in the brief time I was called away to deal with a critical situation at the festival. And while my stage manager was equipped to deal with the fundamentals of running a PA, the actual knowledge of the repercussions of such an act, were not in his repertoire.
Once alerted to the overheating situation, we turned them off for a few hours, and they cooled back down. A few of the drivers were definitely cooked, with weird low ohm readings and the sad sounds you never want to hear, post event. We have replaced two, with another maybe on its way out.
Everything since then though, has been stable. Live and learn I guess
The Othorn tapped hornHide this!Advertise here!
Help with a tapped horn. mike james 533 Subwoofers 33 4th January 2013 11:25 AM
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
