The Othorn tapped horn
Old 29th December 2017, 06:18 PM   #411
Alexlel is offline Alexlel  France
Alright ! Thanks
Not surprising but nothing to lose to take some time and ask !
Hope I'll hear one of those drived by 21" later
Thanks for your quick answer.
Old 29th December 2017, 10:54 PM   #412
Brian Steele is online now Brian Steele  Grenada
Originally Posted by Brian Steele View Post
Can I prevail upon you please to do an FR and impedance curve test on your build with the access panel off and the mouth facing into the ground so it's effectively blocked off? Mucking around with the sims suggests that it might be a quick way to boost the efficiency of the cab and sacrifice a little low end - real-world measurements will confirm if that's the case.
Bump..
www.diysubwoofers.org
Old 30th December 2017, 08:03 PM   #413
blossom is offline blossom  New Zealand
blossom's Avatar
Bump..
infinite audio said "Could definitely rustle something up for you in January"
Old 1st January 2018, 04:19 PM   #414
epa is offline epa  Netherlands
Originally Posted by Alexlel View Post
Hello !
I'm looking forward for informations about the compatibility of the PD1850/2 with the Othorn, would it be something realistic ?
I don't want to deal with 21" speaker and others 18" are requiring a huge amount of power to reach the capacities of the recommanded speakers.
I just want to know if building the cab and put this speaker in is worth it and not ending up with something worst than going for an easier cab ahah, it would be to play Reggae and Dub music which loves those low frequencies.
If my idea is not totally crazy, which plans would be the right ones ?
I read a lot of posts but ain't find something about the combo Othorn + PD1850/2 excepted a simulation but I can't trust it entirely, those cabs are an investment as a student ^^
Maybe I can have as well, the thoughts of the builder !
Thanks a lot,
Wishing you a nice day !
Alex.
superscoop is a good for pd\s&reggea
or miniscoop if you want something smaller
and there are severall designs wich dig deep
keystone,the T118 ,the ft30
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 4th January 2018, 10:53 AM   #415
Infinite Audio NZ is offline Infinite Audio NZ  New Zealand
WOW.... thats all I can say
Yes there are many things you will nitpick about in this photo, buts lets stick to the cream (as Ive said before, us people in NZ are a little 'different' and largely feral). Unfortunately, we were all so busy with things outside of unloading the system, that once everything was completed by helpers and we got back to zone, the design for all the subs lined up together was history (holy crap they are heavy )
I've heard many different systems outdoors in my 40 years on Earth, in many different countries. From Nexo to one of the biggest F1 rigs in the Southern Hemisphere to DIY mashups. I must say, the Othorn is something very special, and I first want to again, thank the wizard Josh, for helping to drop this piece of science into the consciousness of NZ.
My lasting impression, is that the bass seems to come up from the Earth and support you, rather than driving through your chest cavity, taking your breath away and almost forcing you to feel/listen. Paired with the ES18's and Res2's, this system was a joy to listen to, much more than I expected, as there was very little tuning able to be done (due to festival work load and time). Apart from a PEQ on the A&H mixer, very little mucking around with xovers, a one band dip on the highs of the Res2's and some quick 15min calculations for the sub delays, this system was run literally out the gate, and boy were are all impressed, which is a big thing considering one of NZ's top audio techs in the outdoor festival world is part of your team. I believe he even mentioned making 100 of them for world domination takeover, while we enjoyed a few drinks on new years eve
Anyways, I'm tired and just off site, so I hope you all enjoyed you new years.... I'm off to sleep for a week!
Peace
Old 4th January 2018, 04:16 PM   #416
Josh Ricci is offline Josh Ricci  United States
Thanks for the kind words. I'm glad they perform well and everyone seemed to enjoy the bass.
Your comments echo many what I've heard from many others. They seem to make people happy. Guys with plenty of experience with sound/different subs say that they just do something right. I really enjoyed what I heard from mine while I had them. I'm totally an objective / science based person so my opinion is that the totality of the in depth measurements tell the story of why people subjectively like what they hear from these. Or maybe there is some secret sauce...
Cheers
Old 4th January 2018, 09:40 PM   #417
phantom811 is offline phantom811
Hello !
Thanks a lot,
Alex.
Originally Posted by Josh Ricci View Post
Hello Alex,
I do not think those drivers will work well in this cabinet. These cabs need a strong cone, very strong motor and a lot of xmax. With any bass cabinet design you need larger displacement in order to maintain high output to deeper frequencies. This is why a very high power handling, large xmax 21 was used. This enables it to produce comparable output in the upper bass with typical pro cabs with extension to only 35-45Hz and maintain good output to the 25-30Hz range.
Hey Alexlel,
I'm a student and I had the exact same thoughts as yours, the only difference is that my friend had 2 pd1850's laying around, and I was ready to go when I saw simulations.
Dear Josh,
thank you for the plan and this amazing design. It is certainly game changer and beast in it's own league. Here is small report of 2 othorns pd1850 loaded.
I was working 1 and half week on them, most of the time alone.
They need a lot of preparation, precision and budget. In my case I was using
CNC in combination with saw for angles, I had to do a lot of adjustments for available CNC machine. For example I draw everything for 2440mm x 1220mm plates, but later changed everything to different format since price was almost 105euros per plate. Later I managed to cut all costs on 50% with smaller plates.
Once when you have everything cutted things start to get smoother. Tricky parts are braces, if you don't have Kreg Pocket-Hole System or simmilar, but there are ways to do them. Also I had some problems with adapter and putting the 20kg driver in, then adjusting it properly and screwing. I had some mistakes because of 1andhalf week thing non stop full power work, but have to say that I'm more than happy with how did it went.
I finished building everything 45 minutes before my academy was closing, I was literally running to do a small soundcheck. I took tannoy studio monitor, hooked it up to xilica processor and crossed them around 80hz over one othorn.
Can't remember exactly what was the first tune ever, but when the first bassline dropped the whole room started to rumble and resonate. They sound deep, smooth and warm, not very physical but again you kinda feel them.
Didn't had any time left and got kicked out.
Next day I was powering a benefit party that we organised on academy, from 10 in the morning until 10 in the evening. Luckily I had some time in the morning to do the setup. I did rawest estimation on delays and gains for my system, without any measurements. Few minutes later my usb cable got unplugged from processor and that was the last time computer to processor connection was working ever gain (haha )
Anyway, back to othorns. I was powering them up with Proel HPX4600 each driver on one channel, 850W at 8ohms. I have a plan to put more power with limiters (bridge is 4600 2ohms), but I was considered with 500W Xmax problem from simulations that were published here.
Othorns were really warm and precise, but when I've put the volume up, I noticed that one driver had a problem. I could hear paper cone making strange noise, so immediately I've put it down on amp channel. Trough the day I was listening, putting it up and down, but this strange noise would just appear out of nowhere on louder levels.
This is what I was thinking about:
Cone is hitting adapter somehow?
It's probably impossible because driver xmax is smaller than distance to nearest wood
Something like screw was left in horn?
I would hear noise all the time, not just on higher levels.
There is a problem with driver. This pd's were reconed few times, used on heavy dub sound system, tested in other speakers. Probably when reconed somebody who thought that he is qualified person to do it, he didn't placed it in the middle and reconed driver properly?
Or, on the end pd's are just technically too weak for what we want to hear from this box, comparing to what this box is capable to do when loaded properly.
Once when I will be back in country, I will post some updates and hopefully reliable measurements.
ps Infinite Audio NZ you must be a lucky guy, this looooks crazeeeee!!!
Cheers guys!
Old 4th January 2018, 10:38 PM   #418
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
How is the sq of this design?
Old 5th January 2018, 05:02 AM   #419
USRFobiwan is offline USRFobiwan
Horn Addict
USRFobiwan's Avatar
@phantom, swap drivers, try again, if still noise from same cabinet then my best guess is a lose brace or not glued to one of the panels, happend to me once. if noise is now in other cabinet it's the driver
Destroyed some nostalgia
For the love of Horns and glory of pressure waves.
Old 5th January 2018, 05:56 PM   #420
@Phantom - Congratz my bro, super happy for you! Happy to swap ideas at any time, especially once my brain has come to Earth again =/
@Josh - Are you able to take donations? Infinite Audio NZ would like to send you a small percentage of any monies made from the Othorns, from now until infinity. Seems only fair.
The Othorn tapped hornHide this!Advertise here!
Help with a tapped horn. mike james 533 Subwoofers 33 4th January 2013 11:25 AM
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
