The Othorn tapped horn - Page 25 - diyAudio
Old 10th February 2014, 08:44 PM   #241
weltersys's Avatar
Originally Posted by ZivkoF View Post
I have another good contender my TH-1819 vs Othorn
Zivko,
Goes lower, but much bigger than the Othhorn.
Can't cheat Hoffman's Iron Law, but we keep trying .
Art
Old 10th February 2014, 08:48 PM   #242
sine143 is offline sine143  United States
and considering the power handling and xmax of the SW152 in the othorn, I'd expect the driver in the TH1819 to run of of gas quicker (18 with 12.9mm xmax)
I cant find the thread with a search, do you have a link?
Old 10th February 2014, 08:56 PM   #243
Tapped Horn TH-121 build
Old 10th February 2014, 09:52 PM   #244
thanks for the link. Looks like this is the "sim" output. the th1819 runs out of xmax 6db earlier (in passband).
Old 12th February 2014, 11:06 AM   #245
Osse is offline Osse  Sweden
Thank you Art and Josh! It's sad that bfm doesn't declare distortion values... How much distortion does a flh design actually filter out, is there a general rule for a well designed flh cab? Has anybody done any distortion measurements of bfm cabs at full throttle?
Old 12th February 2014, 11:40 AM   #246
I've seen the t48 measurements floating around on here,but the distortion part of it is hard to read( there are no reference points on the vertical axis for distortion, only spl afaik)
Old 12th February 2014, 03:51 PM   #247
weltersys's Avatar
This chart can be used to convert SPL deviation into distortion percentage:
Old 20th February 2014, 02:21 AM   #248
blossom is offline blossom  New Zealand
blossom's Avatar
Would I be correct then that these would be what’s required to reproduce this track and that Xoc1's th18 would fall short here?
Old 20th February 2014, 02:27 AM   #249
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
IMO yes
Dan
Old 6th May 2014, 07:02 PM   #250
kees52 is offline kees52  Netherlands
Hi There
I was a time ago busy with a tapped horn, here the problem was the cone correction, how do you do this here, I did see U use vtc and atc, how do I find the right numbers for a 12 inch woofer if I now vas and Sd.
thanks
Help with a tapped horn. mike james 533 Subwoofers 33 4th January 2013 11:25 AM
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Copyright ©1999-2017 diyAudio
