Hello,
I recently bought a Canton plus s speakerset (4 speakers and a Centerspeaker) at ebay, this set is made in Germany in the ninetys. The subwoofer, that came with the set is not active, so i want to buy a active subwoofer. The set is connected to my Onkyo tx sr607 receiver. This are the specs are: Canton Plus S - left / right channel speakers General Right/left channel speaker : 4.7 in x 3.9 in x 8.1 in Speaker System System Components 2 speakers Speaker Type 2-way - passive Nominal (RMS) Output Power 40 Watt Response Bandwidth 45 - 26000 Hz Input Impedance 4/8 Ohm Sensitivity 87.2 dB 2 x right/left channel speaker - 2-way - 40 Watt - 45 - 26000 Hz - 4/8 Ohm - wired Driver Details Right/left channel speaker : 1 x tweeter driver - 25mm - woven Right/left channel speaker : 1 x mid/woofer driver - 110mm - paper Center: Bauart: 2-Wege Baßreflex Centerlautsprecher Chassis: Tiefton 2x 110 mm Hochton 25 mm Alu-Mangan-Kalotte Belastbarkeit: 60/100 Watt (Sinus/Musik) Wirkungsgrad: 87,5 dB Übertragungsbereich: 40 - 30.000 Hz Übergangsbereiche: 3.000 Hz Impedanz: 4 Ohm Can somebody please give me some advice what sort of subwoofer fit with this set. Thanks Rob Last edited by robbie Peeters; 25th July 2011 at 07:21 PM. |
#2 |
Subwoofer size is dictated by the room, so you may want to include how big your room is.
Also do you want to build your own sub or do you just want to buy a built sub, if building your own sub, your at the right place, if not you may want to go to a different forum that concentrates on built subs like AVS forums
na |
#3 |
What do you want the subwoofer to do? Music, Home theater, earthquake simulations, What is your room size and average listening level in SPL? How low are the speakers you have now flat to In Hz?
#4 |
Here some answers to your questions:
My livingroom is 30 square meters and i will use this set to listen music and watch movies. I want to listen to music at a reasable volume and do not want to blow out my windows. Maybe i am at the wrong forum, cause i will not build my own sub But maybe can somebody give me some advice what to look for. Thanks anyway, Cheers |
#5 |
I've heard good things about these, but I've not listened to one myself.
Rythmik Audio servo subwoofer 12" F12 |
| What sort of PSU is this? | FNQ | Power Supplies | 6 | 23rd May 2011 10:34 PM |
| Another from Seattle (sort of) | bill_a | Introductions | 12 | 4th December 2009 11:36 PM |
| What is this.. some sort of sub? | bluedog00 | Subwoofers | 5 | 12th September 2007 11:26 AM |
| Inductors - what sort? | Tenson | Multi-Way | 11 | 27th April 2007 12:10 AM |
| Off Topic[sort Of] | BOB LEWIS | Everything Else | 4 | 12th January 2006 01:49 PM |
| Page generated in 0.08370 seconds (73.37% PHP - 26.63% MySQL) with 10 queries |
