Where Can I Find Basic Info On Subwoofer Systems? Where Can I Find Basic Info On Subwoofer Systems? - diyAudio
Old 24th July 2011, 04:31 PM   #1
mulluysavage is offline mulluysavage
Default Where Can I Find Basic Info On Subwoofer Systems?
Starting to explore separate subwoofer cabinets in my home systems. What's a good source for learning about incorporating subs into systems, active vs. passive, where and how to incorporate them in the signal path?
Old 25th July 2011, 02:33 AM   #2
qguy is offline qguy  Canada
Send a message via AIM to qguy Send a message via MSN to qguy Send a message via Yahoo to qguy
You may want to add a few more info
Audio only or HT or both
How big is your room
What do you have now in terms of amplifiers and speakers
What kind of woodworking skill do you have
etc
na
Old 25th July 2011, 11:52 AM   #3
I have made several sets of 2- way speakers, as small home systems, out of gourds, yes gourds, and would like to try to add the subwoofer to the mix. So I'm looking for a way to figure out how they are handled in the signal path, etc.
Do I pass the signal through a stereo pot, pre-amp the signal up to line level, then send it to a 25-watt Sure amp, and to a separate sub amp? Or do I go passive and just run dual voice coils in parallel to the L and R speakers with a low-pass filter? Yes, I'm figuring out the basics!
What's HT?
Old 25th July 2011, 09:53 PM   #4
HT = Home Theater
The 2 simplest way is
1. To use sub pre-out from your AVR (HT amp) to your Subwoofer plate amplifier
2. In an 2 channel audio system is to pass the speaker level signals to the subwoofers plate amplifier speaker level inputs
In number 1, the AVR removes the high frequency signals from going to your sub.
In number 2, the subwoofer would have a filter to remove the high frequency from the subwoofer.
na
Where Can I Find Basic Info On Subwoofer Systems?Hide this!Advertise here!
Just an ebay find, couldn't find info on the Ramsa drivers azneinstein Full Range 1 22nd November 2010 09:11 PM
Need info on my Onkyo, can't find any info anywhere. gixxierific Digital Source 0 19th April 2009 03:49 PM
Help me find some info please JPeitzman Tubes / Valves 3 29th November 2007 03:52 AM
Need basic active c/o info Thunau Parts 2 5th June 2003 01:46 AM
Copyright ©1999-2017 diyAudio
