I have 4x SA4518 subs, witch are great, but do not go lower than about 50Hz. http://www.stage-accompany.com/vinta...A4515-4518.pdf To go lower, I can add 4 more 4518īs, but that will only get as low as 40Hz. Not much of an improvement. Questions: Is it possible to build a sub that can cover the 20-50Hz region, and match the output of the 4518īs, without spending 10000 euroīs? And will that sub be small enough to be handled by 2-3 people? Build plans? Best Dirk. P.S. the rest of my PA consists of 2x SA4512īs, 2x SA8535, SA500-900 and X-60. |
#2 |
the gjallerhorn is the only pa sub that play down to 20 (use search)
to go really low you need big cabs and/or lots of power. even for dubstep 32hz seems low enough to me imho. http://www.diyaudio.com/forums/subwoofers/178029-c-e-x-pa-flat-30-ft30-pa-th-awesomeness.html http://www.diyaudio.com/forums/subwoofers/189551-r-evenge-c-omes-f-orce.html http://www.diyaudio.com/forums/subwoofers/183539-plan-request-traped-horn-go-35-ish-120-w-rcf-l18p200.html http://www.diyaudio.com/forums/subwoofers/190635-th-18-flat-35hz-xoc1s-design.html also jbells stadium horn = 30hz maybe you could use the speakers of the4518(jbl ?)and bild a th for it to cover to 100hz |
#3 |
Thanks for the reply epa, but the links donīt work.
That Gjallerhorn looks very cool. That is a beast indead. I wonder what other speakers can go into it, but I could not find any info on the TS parameters of the TS Sounds LMS Ultra 5400. Maybe a cheaper 21 inch can match the TS Sounds LMS Ultra 5400 performance. BTW I have no clue whatsoever on what specs a speaker should have to be able to work in this design. I just want to build a existing design. Experimentations I leave to the experts. Oh and it does not have to be a TH, vented speakers are fine to. I canīt ditch the 4518īs because they are crossovered to high (well above 100Hz I think) |
#4 |
copy/paste the links to the navigation bar.
dont know why they dont.work normal ? i wil have a look if another speaker suits the gjallerhorn. looking @the sa4512 specs they can be crossed @ 100 hz ,dont know if u can change x-over freq on the x-60 Last edited by epa; 19th July 2011 at 03:18 PM. |
#5 |
[QUOTE=epa;2643749]
i wil have a look if another speaker suits the gjallerhorn Epa I was thinking the samething , that it would be good to have a list of all the drivers that work well in all these TH design on this forum. So we don't have to keep asking if this driver work or not. |
#6 |
if someone is willing
the 18 sound nlw 9600(c)works pretty wel in the gjallerhorn. |
| Nak EC-302 / PA-200 schematics wanted... | mdynac | Car Audio | 5 | 20th June 2010 03:10 PM |
| Help wanted for high end diy PA speakers on Audioreview. | Spasticteapot | Multi-Way | 5 | 14th January 2007 02:53 AM |
| 18 inch pa drivers WANTED min 400w rms. | Bull | Swap Meet | 3 | 12th February 2006 07:35 AM |
| 2SA483 Complement | EchoWars | Solid State | 4 | 30th November 2004 07:14 PM |
| Wanted Pioneer PA 1002A IC | zedrider | Parts | 2 | 9th November 2004 07:48 AM |
| Page generated in 0.07922 seconds (78.44% PHP - 21.56% MySQL) with 10 queries |
