Interchanging components with this design
Old 23rd July 2011, 03:51 PM   #21
tb46 is offline tb46  United States
Hi Billyo,
You are talking about a large room and a smallish subwoofer, if you cannot find adjacent room for an in-wall / infinite baffle installation you will have to make a few compromises.
For starters: it would be good to know what your required listening levels are; e.g.: for music? home theather? background?. The Radio Shack sound level meter or any inexpensive sound level meter would be very helpful:
Digital Sound Noise Level Meter Tester Decibel Pressure | eBay
Your desired final size ends up to be roughly a 15-3/4"[40cm] cube, and I assume that means the finished size (including grill and recessed amplifier mounting). That leaves you with a volume that is generally too small for a 12" subwoofer. One possible solution would be to build something around the CSS SDX10 10" sub. You could start with a sealed construction to fit your size requirements, and if you want additional output at the low end you could try a size modified version of CSS's Quartet10 kit:
Creative Sound - Product Details Subwoofer Kit
This adds two passive radiator to the active driver, and will provide much higher output at the low end. For modeling a passive radiator loudspeakers I recommend Jeff Bagby's free software (Excel app.):
Loudspeaker Design Software
Oliver
Old 26th July 2011, 10:34 AM   #22
Billyo is offline Billyo  Australia
Thanks everyone for your help!
Interchanging components with this designHide this!Advertise here!
New free unrestricted PCB design software from RS Components wakibaki Equipment & Tools 12 6th October 2011 04:10 AM
to get a high-end phono stage, is it the design or the components that matters? jasonthegreat Analogue Source 15 17th June 2011 02:26 AM
Allpass filter design using passive components Zodiac Digital Source 2 20th September 2003 05:13 PM
Controversial topic - Components vs. Design Jan Dupont Solid State 151 18th September 2003 05:33 PM
