Old 16th July 2011, 09:40 AM   #1
Default Best sub
Whats the best sub for drum & bass and dubstep ?
Old 16th July 2011, 03:17 PM   #2
tb46 is offline tb46  United States
Small apartment, living room, beach, stadium, dance hall.......?
Oliver
Old 16th July 2011, 03:22 PM   #3
pgolde is offline pgolde  United States
One that gets very loud down to 20Hz if you want to feel everything. Consider the content in tracks that ventures below 40Hz for DnB and dubstep doesn't happen very often, even less below 30Hz, but it does happen. Question is how much do you want to invest for that extra little feeling that only happens occasionally? Things get very expensive (dollars and real estate) to reproduce below 30Hz especially for PA work. For PA build a few of these - Gjallerhorn and buy a high power amp. For home, several small sealed subs will do. There is no best sub, only best for your application, budget, and space. More data required.
Old 16th July 2011, 03:32 PM   #4
We run very small event for about 100 people in a small bar. Want to buy or maybe build something thats going to shake us to bits
Old 16th July 2011, 03:57 PM   #5
DrDyna is offline DrDyna  United States
DrDyna's Avatar
build a couple of the Gjallerhorns that were mentioned, it should have no problem rattling the skin off your bones.
Old 16th July 2011, 04:15 PM   #6
Woow looks like i might find that build a little hard lol Can these be brought pre-built ?
Old 16th July 2011, 04:28 PM   #7
you're on the wrong site, go here JBL SRX728S Dual 18" Subwoofer and more Subwoofers at GuitarCenter.com.
Old 16th July 2011, 04:37 PM   #8
epa is offline epa  Netherlands
there are a lot of topics around for 30 and 35 hz subs
C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
R evenge C omes with F orce
Plan request: A Traped horn to go from 35(ish)-120 w/RCF L18P200
TH-18 Flat to 35hz! (Xoc1's design)
and a lot more
Old 16th July 2011, 04:50 PM   #9
Default ciare horn design by soho
also check out this bass horn design by soho Can this work . last year we build 6 of them for a carnival .the bass coming from them was playing with my heart.
Old 16th July 2011, 06:12 PM   #10
a good friend of mine said that scoops give the best sub bass and 4 would just be silly for 100 poeple. Is he right ? There's some pre-made scoops on the net and they dont that much really.
Page generated in 0.10026 seconds (77.18% PHP - 22.82% MySQL) with 10 queries
