Hi all!
I am looking for a subwoofer for my homecinema, I can have å relatively large woofer under my screen. Height 45 x With 50 x Lenght 225 centimeters, but I cant do hornresp and I dont realy know what to look for, byt I have a understanding that tapped horn is the way to go, can anybody help me? Here are some photos of my cinema/mediaroom, not completely finished, but allmost https://www.facebook.com/media/set/?...0&l=478632b99e Mvh Per Bakkejord |
#2 |
Hi Pirmin,
That looks like it will be a great home theater. Take a look at Volvotreter's tapped horns. They are all very well documented, and you can take any of the Tangband 6.5" versions, and refold them to fit your space. Tapped Horns Another one that comes to mind is lilmike's Insubnia sub using the Exodus Anarchy 6.5" driver, again, refold to fit your space. Reed Exodus Anarchy 25hz Tapped Horn - AVS Forum While tapped horns are critical to the specific dirver, they are also pretty forgiving (if you start with a good design) once you have the basic outline defined. Try to get the throat areas as close to the original design as possible. Maybe this helps. Regards,
Oliver |
#3 |
I have allready looked at volvotreters subs and would realy liked to have the 15" 20hz horn but it is 20 cm to long
Do you really think the 6,5 is enough, can bulid two or even four maybe to fit on each side of the center speaker, will there be a problem if they are firing upwards? And will i miss a lot of low bass in movies? I got some butkikers wich I can put in the sofa for the lowest oktaves... hmm thinking thinking.... |
#4 |
Hi Pirmin,
Only you can decide how much is enough. :-) If you can live with a big horn similar to Volvotreter's 15" 20Hz horn, I would suggest to go with the LAB12 in a single fold tapped horn. I know somebody is going to get upset, but the length is really not that set in stone once you get the basic dimensions around the driver worked out. You can fudge the length quite a bit without major losses. As an example I'll attach a LAB12 single fold SPL (from Hornresp) at the full design length, and with 40cm take out of the middle (minus 20cm box height).The LAB12 is a good driver, it gives a lot of room for experimentation. If you can work in multiple enclosures I would go with the Anarchy 6.5". If you want to put two drivers into the same box: mount the drivers close to each other, and double all the cross-sectional areas without changing the path length. Regards,
Oliver |
#5 |
there is also a 230cm version of my Eminence TH: http://www.volvotreter.de/downloads/...30cm_Rev_0.dwg The only difference is that L23 is 362,60 cm which results in a maybe 2Hz less low end extension. I just cut the length in the drawing and adjusted things around. If required, your 225cm can also be achieved by cutting it a litte further down. Regards Erik |
#6 |
Wohoo!!!
I will build your design, 230 is possible with a few tweaks... Thx Per |
#7 |
Sorry about the missiong attachement.
Oliver |
| LM3886: Mute Capacitor Cm | mudihan | Chip Amps | 1 | 24th July 2008 02:48 AM |
| Carver CM-1090 | Frazzled | Solid State | 8 | 24th May 2007 01:03 AM |
| IMF cm 2 front covers ? | itsme1 | Multi-Way | 0 | 25th November 2005 07:43 PM |
| How much CM range does a differential need? | Kevinbd | Solid State | 5 | 1st November 2005 03:38 AM |
| Question for Member from Singapore CM | Alvinttt | Digital Source | 23 | 7th November 2003 09:44 AM |
| Page generated in 0.09642 seconds (73.70% PHP - 26.30% MySQL) with 11 queries |
