I’m considering build a sub using the Dayton 12” HF-4 (this’ll be my first build), I’m modeling it in WinISD. The sub would be a net 4.1 ft3 box with two 4”x 37” ports tuned to roughly 20 Hz.
When I set the power to 250W excursion is well controlled above 17 Hz and it generates a flat curve at about 108.5 – 109 Db above 28 Hz. When I up the power to 400W I get a flat 110.5 - 111 Db in the same frequency range and excursion goes above Xmax + 10% in an area around 28.5 Hz. Does WinISD model this accurately? Adding 150W only boosts SPL by 2Db but excursion goes up by 4mm? I’m wondering if I really need a 500W amp for this setup or if 300W is going to be both safer and sufficient. Probably some of this has to do with the room and room setup: (20’ x 15’x 8.5’ rectangular carpeted, open beam ceiling, 5 open entryways of about 30” each). I’d rather not try to control excursion at 28.5 Hz by filtering… any ideas about this? |
#2 |
Did it Himself
The box is a bit too small, hence why it's bottoming out at 28Hz.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
I'll assume that you are talking about the Dayton RSS315HF 12"
Generally you are not going to run your sub(s) wide open since you want them to integrate with the other speakers in your system but you do want them and the sub amp to be capable of clean undistorted peak levels when necessary. The Xmech of that Dayton drivers is about 20% higher than their linear Xmax limits. Most music and HT use is not a steady sine wave at one particular frequency but rather is dynamic - you should probably OK with your design but f you could make your enclosure closer to 6 ft^3 you would see a smoother response and less of a Xmax hump @ around 28Hz. If the price differential between the 300W sub amp and the 500W sub amp isn't too bad I would go with the 500W amp Last edited by Cokewithlime; 14th July 2011 at 07:58 PM. |
#4 |
Hmm, maybe I'm doing something wrong but, WinISD indicates that, keeping all other params constant, adding more volume to the box increases excursion and port velocity. The param that seems to decrease the 28 Hz excursion is moving the port tuning closer to the problem area i.e. to a higher frequency.
That kind of makes sense, a larger volume of air doesn't provide as much damping as a smaller one. Anyway I added in a 2nd order High Pass filter at 20 Hz and bumped the tuning to 21.5 Hz and things look much better! |
#5 | |
It also reduces output level, requiring a few decisions: Will the additional power required offset the lower efficiency of the smaller box? Will the driver sound as good when pushed harder to make up for lower efficiency ? Design is fun. |
#6 |
yeah, I realized it as soon as typed it up.
#7 |
some hints:
add a second order hi-pass at 18hz. (all the dayton amps have it.) use 4.3ft^3 limit yourself to 250w with that driver in a BR box. excursion is the limiter in a BR box not power. 108db will be enough. Your ports look good at 36"x4" port velocity at 20hz is under 10m/sec. edit: i should mention, I've used that driver often. in a 4.3ft sealed box with a 240w amp it kicks like a mule and sounds great, better than BR . Last edited by revboden; 14th July 2011 at 10:42 PM. |
#8 | |
So to look at the issue of reduced efficiency due to having to overcome the greater resistance of a smaller air volume, I increased my box volume from 4.1 ft3 to 6 ft3 while looking at the SPL graph. My nice flat curve got a + .5 Db bump at 27 Hz and a slight decrease in Db at higher frequencies. The frequencies below 25Hz got a more of a boost by about 1 - 2 Db. But excursion becomes problematic at 28Hz again so I'd likely have to raise the port tuning which would reduce some of these low freq. gains. All in all I can't say the increase in box size by about 50% is worth the boost below 25Hz, at least IMO. Last edited by Sonoran; 14th July 2011 at 10:38 PM. |
#9 | |
Is a 2 Db boost really that noticable? Is a "BR" a vented box? I figure I'll make the vented box and if I want sealed output, say for music or something, I'll just plug the ports. Best of both worlds IMO |
#10 |
sorry,
one more thing, if you are crossing over higher than 80hz the 36-37" port will ring. for a crossover at 100hz limit yourself to 32" length unless you use an elbow. Then each section should be less than 32". |
| USB Driver kit with Display & Remote Control. | samim_kp | Digital Source | 0 | 17th September 2010 05:28 AM |
| Built box too big, how to control excursion? | Jameson Styles | Subwoofers | 1 | 11th October 2009 05:54 AM |
| OB vs BR: driver excursion | bvan | Full Range | 5 | 13th January 2009 07:20 PM |
| Hornresp: driver excursion? | e-side | Multi-Way | 5 | 11th December 2005 06:48 PM |
| driver modifications to double the excursion | Jared | Multi-Way | 16 | 16th February 2003 03:04 AM |
| Page generated in 0.10771 seconds (83.56% PHP - 16.44% MySQL) with 11 queries |
