Ok so im building a sub woofer box for an old sub a friend gave me, I have a crossover from the inside of a technics speaker, the crossover has wires for a tweeter, midrange and sub, if I wired the sub up would I get all the power going through to the sub?
please dont try to kill me if this is totally newbie, gotta start somewhere, thanks, harry |
#2 | |
If you connect the amp to the input of the passive crossover, and wire the sub up to the woofer output of the crossover, if the sub speaker's TS parameters are identical to the Technics speaker, the subs upper response will be rolled off (probably around 300 or 400 Hz, three or four octaves higher than subs are normally crossed) and (basically) nothing will happen to the sub's low response. Since it is unlikely that the sub's TS parameters are identical to the Technics speaker, some goofy response curve will probably result. Passive crossovers are difficult to "get right", even with test equipment. Have fun, good luck. Art |
#3 |
the LF tap on that board is for a woofer not a subwoofer. The filter is set for between 500 and 800hz. 80-800hz is woofer territory. sorry.
#4 |
what? thats confusing haha, the crossover is from a technics sb-cs7 speaker box, the woofer or low range driver or whatever played right down to 30 hz.. well moved, it sounded good until 40 hz, so I either dont know what Im talking about or something
#5 |
Threads merged.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
The crossover determines the upper roll-off, not the bass extension, it won't work. Get a plate subwoofer amplifier, its far more flexible. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| Will this Crossover work? | farmerjack61 | Multi-Way | 44 | 6th March 2011 03:47 AM |
| Can this crossover work in my speakers ? | kyu | Multi-Way | 5 | 5th September 2008 10:28 AM |
| Tried assembling my own crossover...why didn't it work? | PoorSound | Multi-Way | 5 | 16th February 2008 07:02 PM |
| Tweets don't work on my new crossover! | lemans23 | Multi-Way | 23 | 28th February 2007 02:38 AM |
| Page generated in 0.07664 seconds (74.37% PHP - 25.63% MySQL) with 10 queries |
