I own a VERY small Ford Ranger. The cab has literally no room for anything. I am upgrading the speakers.
Now that I have caught you up in broken sentence form, here is my idea. I will put a subwoofer in the bed of the truck, and connect it to the cab via a plexiglass channel. The channel would be a rectangle and have to be about 5" long. Kind of like a bandpass where the whole front volume is the port. I was just wondering what kind of enclosure this would be, what kind of speaker I should use, and anything else pertinent to this decision. |
#2 |
Well, this would be a 4th or 6th order bandpass sub. You can use something like WinISD to model it.
Personally I would go for a 4th order bandpass design, but that's just my 2c.. |
#3 | |
That could be done: Look at the first picture in: H-PAS patent pending to Atlantic Technology b |
#4 |
#5 |
I had a standard cab '92 ford ranger for a couple years. (similar or smaller to what you have) I put in a 'baffle board' that sealed against the rear of the cab and 'just' had room for a pair of high power 8" drivers flush mounted so the seats would slide back tight to the board. (couldn't really call it a cabinet, but it effectively created a relatively sealed cabinet)
Upgraded doors and cut 2" mid/tweet in the pillars. It was kinda like one of those vibrating chair kind of things.... it was really cool with the front/rear loading on the 8's. It was almost stealth with the exception of the pillars, no loss of room, and no compromise in the bed. (well, the jack/lug wrench had to find a new home, but that was it) I know it's not what you are asking -- just fyi... |
#6 | |
#7 |
#8 |
#9 |
I actually helped a friend of mine do this with his Dodge Dakota. He put a sealed cabinet in the bed of the truck about 1 foot away from the front. We mounted wood around it so that it sealed against the front of the bed, basically turning the front section of the bed into a bandpass. We cut a hole through the bed about 6 inches tall and 20 inches wide, and then another hole in the cab, so you could see into the bed (but saw the sub cabinet when it was installed.) We sealed the gap between the bed and cab with rubber.
I think we used a pair of Kove audio 12" in the cabinet with...I believe it was a soundstream amplifier, somewhere in the neighborhood of 2000 wpc. Needless to say, he liked to play bass music, and let me tell ya, some of the tracks on "Bass Mechanik" would jump his wiper blades off of the windshield by an inch or more. Sounded the best with the windows rolled down about 4 inches or so. Edited some oopsies. Edit2: Here are the drivers we used. http://www.caraudio.com/forums/car-a...12-*rare*.html Last edited by DrDyna; 12th July 2011 at 03:46 PM. |
#10 | |
From what I can tell, it'd act as a sealed box. 5" distance when the wavelengths are measured in feet isn't of much relevance, IMHO.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
| Subs for a Carnival truck | ljk11 | Subwoofers | 2 | 20th June 2011 12:28 PM |
| Truck underseat sub | x. onasis | Subwoofers | 2 | 23rd January 2010 02:48 AM |
| truck sub box | d3imlay | Subwoofers | 2 | 17th June 2008 04:56 AM |
| What Box In My Truck? | 26sonmytruck | Subwoofers | 1 | 15th May 2006 03:08 PM |
| Page generated in 0.10467 seconds (84.46% PHP - 15.54% MySQL) with 11 queries |
