im looking at this and wondering if it has any real world benefits?
http://www.forum.poweraudio.ro/downl...=709&mode=view |
#2 | |
Some drivers are not “tough enough” for horn loading, the difference would be more apparent with a less rigid cone. Most designers abandoned “W” type designs and use spiral folding to achieve longer path lengths in similar cabinet volume with less wood, weight, and complexity. Path length is much shorter per cabinet volume, so low corner is higher with this type of cabinet than one using a single path. Art Welter |
#3 |
#4 |
art... that's stipe's 45hz tapped horn.... It's a recent design....
http://forum.speakerplans.com/beware...html?KW=cyclop Last edited by jbell; 8th July 2011 at 11:09 PM. |
#5 | |
Since electronic amplification got into the sound picture, and lower FCs have been pursued, various folding schemes have been used. The W bin is but one of the many. Given the same driver, mouth and throat size, a longer horn goes lower and louder. Given the same cabinet volume and mouth size, the longer horn will go lower, but the shorter horn will be louder down to Fc (horn cutoff). Put them in multiples, the longer horn will gain more down low compared to the shorter horn with a higher FC. Translate that in to terms of "authority" however you want .Art Welter |
#6 | |
that helps me a lot, thanks |
| Output Pentode Screen at half Plate voltage | Andrewbee | Tubes / Valves | 32 | 2nd May 2012 11:41 PM |
| Aleph 30 problem - half of power supply voltage on speakers output | yoke | Pass Labs | 18 | 15th March 2009 05:18 PM |
| odd: half-bridge, no rail voltage but still drives speaker? | jwagnerhki | Class D | 3 | 26th April 2006 11:06 AM |
| splitting a 50W output across 3 speakers? | MR2_ICE | Car Audio | 14 | 1st March 2004 06:34 PM |
| Page generated in 0.09188 seconds (74.88% PHP - 25.12% MySQL) with 11 queries |
