i wil update the plans soon.
Not to sound confuse EPA make the entire plan for 3/4" ply.
So now I have to increase my bench push to get stronger.
plan 1 (more will follow)
Epa can the above plan be done large enough to be use as a template, so it can be trace on the plywood .It would make building easier.
Some like this would be great.
you mean so you can print it on paper?
yes depending on what size the copyshop can print for you.
you need ~31"x40"
you can ask the copy shop if they can print *.dwg or *.dxf files.
that would make life much easyer.
Already did my homework. The copycenter can the above size and file.
see if these file are good
its like the pic without the yellow measurements(wich are in inches btw)
http://seijs22.home.xs4all.nl/mcm8.dwf
http://seijs22.home.xs4all.nl/mcm8.pdf
Nice work Epa,is this plan upated to be use with 3/4" plywood are that update is coming later.
Thank
epa divide the measurments from post 67 [1 / 2.54= units= inches said:[/QUOT
Do not understand the above statement.
in the pic above you can see the bottem right the thicknes 0.75=3/4
Can you indicate the areas and the plan that will use 3/4" plywood.
the magenta line is the hornpath.
http://seijs22.home.xs4all.nl/mcm8 12mm1.dwf
http://seijs22.home.xs4all.nl/mcm8 12mm1.pdf
http://seijs22.home.xs4all.nl/mcm8 12mm2.dwf
http://seijs22.home.xs4all.nl/mcm8 12mm2.pdf
all 12mm mdf
you want prints for the internal section post 67?
thats all 1/2 ,but you can make it 3/4 ,just keep the path dimensions the same
I think I will use 3/4" for the entire plan, that would make things easier for me to understand
- Subwoofers
- Mcm 8" 55-2421 Ts parameter
