Mcm 8" 55-2421 Ts parameter
Old 28th August 2011, 03:53 PM   #121
kornnylike is offline kornnylike  United States
Epa, any step by step instruction on building this bass horn
Old 31st August 2011, 12:41 AM   #122
Default Template
Time to get down to business. Here is a large print out of the plan to make a template to start building.
Erik check your pm
Old 31st August 2011, 01:28 PM   #123
ODougbo is offline ODougbo  United States
Default 55-2421
I have bought about a dozen of these woofers and made about a dozen cabinets. They are okay, certainty a good deal for the $$ (can be bought on sale for $30). The manufactures did make some improvements on the design a few years ago.
As far a cabinet HUGE, e.g. 2cf, tune vent to 30hz, youll get crazy low bass. However, take it easy on the volume, they can be damage in loud action scenes. I would do not recommend them for car applications.
Id go for the isobaric design (cut the volume in half and theyll handle a lot more power), I did post a couple of pics this morning of the subs Im using, with the 55-2421.
Recently I built two boxes (2 woofers each 4 woofers total), one on each side of the room. The bass is amazing, better than many store bought subs. BTW, the bass is quite strong, even down to 25hz.
Old 31st August 2011, 02:15 PM   #124
As far a cabinet – HUGE, e.g. 2cf, tune vent to 30hz, you’ll get crazy low bass. However, take it easy on the volume, they can be damage in loud action scenes. I would do not recommend them for car applications.
I’d go for the isobaric design (cut the volume in half and they’ll handle a lot more power), I did post a couple of pics this morning of the subs I’m using, with the 55-2421.
Recently I built two boxes (2 woofers each – 4 woofers total), one on each side of the room. The bass is amazing, better than many store bought subs. BTW, the bass is quite strong, even down to 25hz.
Nice work ODougbo, as for me I will be starting building very soon,as soon as Epa supply me with some more templates to make building easier and more accurate.
Old 2nd September 2011, 04:17 PM   #125
epa is offline epa  Netherlands
that doesn't sound right .
if u measure the template 11.87 and the 12.78 ,do those sizez measure the same?
if not, they did not do a 1:1 copy ,but a "fit to page" copy
edit/it should be aprox 34"*41"
before you print again,wait til i have the complete plan with all pannels 3/4(also the red one)
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 2nd September 2011, 05:00 PM   #126
Ok I will wait.
Old 2nd September 2011, 05:06 PM   #127
did they print it right or not?
also can you measure the wood thicknes exactly "slide rule"
. hr driver db
Old 2nd September 2011, 05:10 PM   #128
The machine as acting up so the fedex manager print it from photo shop.
That what I heard
I do not know if they edit the file.
Old 2nd September 2011, 06:03 PM   #129
The wood thickness is a little more than 3/4" about 5/8"
Old 2nd September 2011, 08:25 PM   #130
can you measure with something like this?
usualy 3/4 ply is less~ 0.71"(18mm)
. hr driver db
Mcm 8" 55-2421 Ts parameterHide this!Advertise here!
MCM 55-2421 T/S Parameters and thoughts greg_mcquaid Subwoofers 11 3rd September 2017 09:35 AM
Silly's 1st Sub -- 8" MCM 55-2421 Sillyboy Subwoofers 31 11th July 2014 05:24 PM
MCM 55-2421 Vented Enclosure? cj.9 Subwoofers 2 11th May 2006 06:12 AM
Question regarding the MCM 8" Woofer (Part #55-2421) Phlim Subwoofers 2 2nd February 2006 11:46 PM
Looking for MCM 55-2421 Woofer lancer Parts 0 5th December 2004 06:03 PM
