A long,long time ago I played bass guitar thru a Fender open backed 4 10 Bassman amp, 50 watts tube.I see that Parts Express has their 292-412 cheep 12 on sale.
Four of these in an open back box,the Qts is 1.54, Fs is 35,xmax is 3.5 mm. At what power level do I run out of xmax for open E, 41 Hz? Or would this be only suitable for guitar at 82 Hz? Trade offs for U or H frame depth, etc. Thanks! |
#2 |
GRS 12PF-8 12" Paper Cone Foam Surround Woofer
that one ? id guess you could run maybe 100 watts int 4 of them (open back) without issue. would be loud enough for playing with a drummer (just) |
#3 | |
Get acquainted with HR and you can reply more accurately. b |
#4 |
Bjorno;
Why the two zero length, zero area segments between the front and rear chamber? I have never used HR to model OB before.
mike - www.keepingsundayspecial.org |
#5 |
#6 |
With a 50 Hz HP.
EG is voltage, voltage squared /impedance ends up with the speaker hitting Xmax at 9.5 watts, a whopping 100 dB at 40 Hz. Open baffle can sound OK for musical instrument use, but they don't make low bass for squat. |
#7 | |
Best way to model a H-Frame (OB) is in HR to invoke the CH(compound Horn flag) when in the main HR screen. Result: The zero areas/segments are no longer valid. Here zero length and zero area means = labels not in use. b |
#8 |
No but if Eg = The input voltage is set to 28.28 V (Rms) into 8 Ohms, the applied power to the driver load is U^2/R = 28.28^2/8 = 100W.
See the picture where the SPL and cone excursion corresponds to 100W input. b Last edited by bjorno; 2nd July 2011 at 11:57 PM. |
#9 |
ok about 40 watts @ 41hz,
not 100. optimism got the better of me again :/ |
#10 |
Why not accept there's not going to be any low bass coming out of it, and add a high pass at ~80Hz instead?
It'd take 100w easily, and would give a lot of "tone" - harmonics instead of fundamentals.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
| Linkwitz's Xmax calculator question | cuibono | Multi-Way | 4 | 3rd February 2009 08:14 PM |
| Question about xmax | mitchyz250f | Subwoofers | 12 | 2nd August 2008 08:02 PM |
| Xmax Question | morfius | Multi-Way | 5 | 15th April 2008 09:26 PM |
| IB driver spec question... | moray james | Subwoofers | 3 | 18th December 2007 07:27 AM |
| Xmax Question | jwatts | Multi-Way | 13 | 5th February 2005 12:11 AM |
| Page generated in 0.09833 seconds (78.68% PHP - 21.32% MySQL) with 11 queries |
