Old 25th June 2011, 01:01 AM   #1
Default Having one of my stupid thoughts
An 18' sub woofer but the coil isn't moving the inside of the cone, The inside of the cone is mounted to the frame. The coil and magnet are on the big diameter of the frame.....somehow......You would get a lot more cone movement that way thus moving more air. Maybe getting it to go at a lower freq. See I told you it was stupid.
Old 25th June 2011, 04:23 AM   #2
60ndown is offline 60ndown  United States
my guess is cone movement would be about the same, cones are stiff, you move the middle forward 6mm and the outer edge moves forward 6mm.
i think?
Old 25th June 2011, 04:34 AM   #3
Some are. Some aren't. Ever see a cone when DC voltage is applied to it? The offset movement is very obvious. This kills drivers pretty quickly however.
Old 25th June 2011, 07:59 AM   #4
chris661's Avatar
Yeah, that could work, buuuut...
If you've gone to the trouble of using such a large coil, why not make the cone even bigger?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 25th June 2011, 02:59 PM   #5
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Didn't Morel do something like this?
Old 25th June 2011, 03:17 PM   #6
The object is to drive the cone in a manner least apt to cause flex and breakup. That usually means driving it somewhere between the ID and OD. Here's another thought- if you want to drive the OD, it might be easier and cheaper to run an electromagnet around the OD, rather than permanent magnets. It could even have some cool looking fins to keep the windings cool. I've always been surprised that, other than some ancient radios, nobody uses active magnets. There might even be some tricks to drive the magnet from another differential power channel, controlling the current to control the damping of the system. It might be possible to get lower response in a smaller box without gobs of power.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 26th June 2011, 01:23 AM   #7
What drove me to this is crazy thought was that Damn Thigpen and his Rotary woofer... I Just wonder if theres another way to get down as low as his but with out the complexity of his, and I think the only reason it can get that low is because it's moving way more air..., Just seems like theres should be a different way to achieve those lows without paying 20,000 dollars. .
Old 26th June 2011, 02:23 AM   #8
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
What about an array of motors mounted in circles under flat stiff diaphragm, like some metal foam? Such a huge open baffle, all moving... Like a gong in Buddhist temple...
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 26th June 2011, 03:45 AM   #9
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Kinda like this??
__________________________________________________ _____Rick........
Old 26th June 2011, 06:36 AM   #10
Originally Posted by Richard Ellis View Post
Kinda like this??
Yep just like that!!!!
Well I must be stupid then ! nigelwright7557 The Lounge 2 25th July 2010 03:09 AM
New and stupid. gbeard Introductions 2 28th December 2007 02:50 AM
This might be stupid but... CJ900RR Multi-Way 3 28th April 2006 12:53 AM
This may be stupid but.. skyraider Digital Source 1 17th December 2004 10:39 AM
....and now for something very stupid..... bob4 Everything Else 2 23rd December 2002 04:00 PM
Page generated in 0.11220 seconds (81.73% PHP - 18.27% MySQL) with 11 queries
