Old 19th June 2011, 10:40 AM   #1
Centvrion's Avatar
Question Hint needed: QWTL with 2x Monacor SPP-200
I have a pair of Monacor SPP-200. Is it possible to use them in push pull configuration inside a transflex unit tuned at 30Hz?
How much does it matter if they have high QTS(=1)?What would be the result?
Old 19th June 2011, 02:05 PM   #2
epa is offline epa  Netherlands
post the ts ,and i could sim it for you
Old 19th June 2011, 02:08 PM   #3
Centvrion's Avatar
Thank you so much epa!
MONACOR INTERNATIONAL : Dettagli del prodotto Page
Old 19th June 2011, 08:26 PM   #4
nothing decent sofar.
i wil try some more later.
Old 19th June 2011, 09:24 PM   #5
Centvrion's Avatar
Ok...I will wait:-)
Thank you again
Old 20th June 2011, 12:40 AM   #6
revboden's Avatar
Something new... What is Transflex?
edit: never mind, found this
Old 20th June 2011, 08:09 AM   #7
Centvrion's Avatar
Yeah! That's a Transflex!...It's one of the 3(or 4?) pages from the original Jensen 1952 project.
I have already built a pair of towers tuned at 40Hz, but I used a pair of speakers (6,5") (as subwoofers) from a bass reflex system tuned at 40Hz, so, even if I didn't know TS parameters, I thought (right) it was possible: great result.
But now the "problem" is that a friend of mine gave me that pair of speakers and I don't know if they fit into a Transflex (in push pull, isobaric), mainly because of their high QTS (for what I know, reflex speakers have low QTS). Is this parameter so important for this kind of loading?
If anyone with some experience or simulator (as epa) could help me...
Old 20th June 2011, 03:20 PM   #8
sorry ,can't get a decent model with this one.
a 200 + ltr cab and already over excursion @ 2.83 volt.
all peaks and dips.
Old 20th June 2011, 04:20 PM   #9
Centvrion's Avatar
Ok...Qts too high...Thank you very much again epa.
Which simulator did you use?
Monacor IMG Stageline STA-900 transistors, help needed Jonas83 Chip Amps 0 15th July 2010 09:33 PM
QWTL and Half WTL in the same BIB cabinet tizio_82 Multi-Way 4 8th May 2008 03:49 AM
Phase Linear Model 200 help needed Original Burnedfingers Solid State 14 11th November 2006 02:54 PM
Yamaha NS-200 mod/upgrade suggestions needed. GregGC Multi-Way 17 17th February 2004 02:04 AM
Monacor SP 60/8 needed Cambe Swap Meet 1 1st August 2002 12:59 PM
Page generated in 0.09118 seconds (74.10% PHP - 25.90% MySQL) with 11 queries
