Hello
Could someone help me find T&S parameters for the NX750P YORKVILLE bass speaker ? I got a free pair of these (without the class D amps) and I'd like to using the 15" bass speaker in a correctly calculated bass-reflex wood cabinet, not for real HiFi purpose, but for a clean and private PA system. Yorkville part number should be 7410 Official Yorkville documents shows no info about T&S parameters. Thanks |
#2 |
If nobody responds you could take the driver out and make pictures from all sides. It is more likely somebody recognises the driver from seeing a picture.
#3 |
Hello Djim, thank you for you advice, so I join 3 picts of this bass speaker from this Yorkville NX750p.May be someone knows the manufacturer of knows Yorkville EOM. Replacement speaker should be 7410 (Yorkville part#) but tag said 15/306 - 8 which I presume means :
15 inches : diameter of aluminum frame 306 mm : diameter of paper cone 8 Ohms. No big help isn't it ? Yorkville says it has a Neomydium magnet. So.. Have a look and try to recognize this speaker... Is it Chinese or US made ? (Even in China they have Thiele and Small parameter do they ?) Many Thanks anyway FrenchGuy |
#4 |
#5 |
#6 |
Bingo ? It looks like it... let's wait for few days to see is other answers are coming..
If it's a B&C, we should get the T&S parameters quite easy I guess ? |
#7 |
Clicking on the lettres bleues would even give access to a French guy!
#8 |
looks pretty damn similar to me! but thats just going by looks....i'm guessing you don't have anyone in the area that has equipment to measure the driver for you?
#9 |
Well I found the confirmation B&C is a OEM for Yorkville so that'it ! The B&C 15NDL76 is the bass speaker of the NX750P. I have the T&S parameter (thanks for the link, Djim) and I'm going to optimize a bass-reflex cabinet for these speakers. Thanks to all of you.
| Tube Parameter "Attenuation, Harmonic" What is it? | TheGimp | Tubes / Valves | 5 | 4th May 2010 05:58 PM |
| FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 | nl | Swap Meet | 2 | 10th June 2009 10:15 PM |
| Which is the most important TS parameter? | Wombat2 | Multi-Way | 7 | 18th July 2006 11:27 PM |
| Help finding TS parameter/driver indentification please (pics) > | beady | Multi-Way | 2 | 1st August 2005 09:41 AM |
| PANASONIC capacitors TS-HA or TS-HB! Other caps? | ulysse21 | Parts | 2 | 25th March 2004 07:10 PM |
| Page generated in 0.11566 seconds (78.56% PHP - 21.44% MySQL) with 11 queries |
