40Hz TH
40Hz TH
Old 12th April 2012, 07:01 PM   #81
Dag Johansen is offline Dag Johansen  Norway
Originally Posted by Dunderkeppan View Post
How did you bolt the drivers on ? Did you use T-nuts on the other side and normal bolts to fasten it ?
For now its just screwed in the wood, but when they come in for a service/paintjob next time i will mount t-nuts!
Dag
Old 12th April 2012, 07:15 PM   #82
Originally Posted by CRESCENDO View Post
Vented/bass-reflex or front loaded horns? And which model(s) are you comparing them to?
I have swapped back and forth with SB1000, which is about 35% bigger in volume.
I did not meassure it, but i estimate the difference to be around 6-7dB's in favour of the tapped horn.
I'm not sure, but i think SB1000 is a 4ohm subwoofer.
I have also compared it to a homemade box with 2 Eminence 3015LF same size, and i have to say, the difference is huge in the 35-40Hz region.
Dag
Old 13th April 2012, 08:49 PM   #83
epa is offline epa  Netherlands
hi dag.
it seems i shamelessly copy'd your fold.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 13th April 2012, 08:52 PM   #84
Originally Posted by epa View Post
hi dag.
Haha, thats ok, i think we are running out of folds these days!
Dag
Old 13th July 2012, 02:33 PM   #85
So, measurements any day now..
Any inputs apreciated.
White noise, sine sweep?
2,83volt or 28,3?
I will use Ipad with calibrated mic, Audiotools app.
How far from nearest building?
Dag
Old 13th July 2012, 04:17 PM   #86
weltersys is offline weltersys  United States
weltersys's Avatar
2,83volt or 28,3?
Dag
Dag,
Nice looking build!
28.3 volts sine sweep at 10 meters would be good if you can get several wavelengths (20 meters or more) away from any buildings.
Tests of 1, 2, 4 and 8 cabinets would be nice. The cabinets should be brought out and stacked in that order, as surrounding cabinets, unplugged or shorted have an effect on response.
Art
Old 15th July 2012, 09:56 AM   #87
martinsson is offline martinsson  Sweden
Really nice build, even if they're not THAM's
Looking forward to the measurements and thank's for sharing, this is why I fawouur open community development where the knowledge is free and shared, the best way by far, compared to the locked in proprietary models.
Hoppas allt går bra med mätningarna, vem vet, kanske hör något avlägset muller här i Göteborg
Old 26th July 2012, 10:18 AM   #88
reminence is offline reminence  Australia
just wanted to double check that the ande lb1560 drivers would be a good match for the 40hz th?
JDs Sound and Lighting. Ande LB1560 15" 600W 8 ohm driver / speaker
Old 26th July 2012, 04:55 PM   #89
Its not optimal, it becomes more like a 55Hz TH.
Dag
Old 26th July 2012, 09:07 PM   #90
tb46 is offline tb46  United States
Hi Dag Johansen,
Yes, really nice build. By the way, if anyone needs two new, unused, untested LAB15 drivers (loacated in Texas) pm me.
Oliver
40Hz THHide this!Advertise here!
Help needed 40Hz to 450Hz 3GGG Multi-Way 10 8th February 2011 05:32 AM
DIY 40HZ TH for DJ use NEO Dan Subwoofers 10 29th January 2010 08:56 AM
40hz seems too much Kelloggrice Subwoofers 7 29th March 2007 12:30 PM
I want a subwoofer flat from 10hz-40hz Audiophilenoob Subwoofers 123 13th December 2005 05:10 AM
40hz horn modeled mikee12345 Multi-Way 0 30th September 2003 05:45 AM
Copyright ©1999-2017 diyAudio
