40Hz TH
40Hz TH
Old 19th December 2011, 12:56 AM   #61
Brian Steele is offline Brian Steele  Grenada
Originally Posted by reminence View Post
Is there no way to get this design to be a carry-able weight (one person) ie 30-34kgs? if I use thinner material and this driver? JDs Sound and Lighting. Ande 15" LB15-1 350W driver / speaker
Small-loud-40Hz and below - pick two :-)
The only way to get a smaller cabinet is to use a smaller driver. Even then, the folding may have to be a bit different. One possibility - look at car audio "SPL" type 10" drivers (50 Hz<Fs<60 Hz, 0.3<Qts<0.4, good Xmax). It should be possible to get a good TH out of them, but you're going to lose 3~6dB of sensitivity in the process. However, you can build multiples of these to get back that efficiency, and each box should be quite portable if done right.
www.diysubwoofers.org
Old 19th December 2011, 04:44 AM   #62
mimura is offline mimura  Thailand
thank you
Old 30th December 2011, 03:45 AM   #63
CRESCENDO is offline CRESCENDO  United States
40Hz TH
Originally Posted by tb46 View Post
Hi Crescendo,
In the singlesheet thread I suggested a bigger version, about 22"x32"x48", would that be too big for you? It goes roughly 10Hz lower than the SS15.
Did you post an image/plan/hr input or just the idea? If you did, approximately what page?
Old 30th December 2011, 03:49 AM   #64
40Hz TH
Originally Posted by Dag Johansen View Post
Cluster of four @ x-max, not bad i think.
It is worth to notice the size of this cab, it is actually small, about 30% smaller than TH-18 (Xoc1's design) and TH 115/TH 118 by Danley.
Dag
Is this modelled w/the LABs? I don't get nearly that smooth of a response to 40Hz (and -7 or 8dB @ 35) w/the HR input info you gave in post #9 w/the 3015LF
Old 30th December 2011, 09:09 AM   #65
Dag Johansen is offline Dag Johansen  Norway
Hi Crescendo, i'll admit this tread is a little confusing.
The 3015LF version is over and out, it sounded good, but the cone came loose from the spider using less than 500 watts even setting the subsonic to 35Hz.
Now it is LAB 15 and it sounds very good, it have all the atributes of a good TH.
Here are my Hornresp inputs, i have meassured my own set of Thiele-Small data after some break in. (its not that different from the manufacturers data)
My goal was to hit 100dB's @ 40Hz, and i think i have done that.
Black trace, 4cabs - grey trace, one.
Dag
Old 30th December 2011, 11:08 AM   #66
40Hz TH
That looks great - terrific job!
That's too bad about the 3015LFs; I've got 6... 2 are in jbell's SS15s, 2 are in BFM T48s and 2 are still in the box. But, I'm looking for more <40Hz for the dnb/dubstep shows I do, so the search continues (until more money comes along to buy more amps and build some 18" THs).
Keep up the great work!
Old 30th December 2011, 12:32 PM   #67
epa is offline epa  Netherlands
hi justen
a straigt th of 6 or 7' long works wel for the 3015 ,all area's 1000 or 1100cm2.
not verry efficient but with 3 a side ,wil preform good till 30 hz in a 250-300 ltr cab
easy to design and bild
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 30th December 2011, 09:30 PM   #68
40Hz TH
Looks pretty good for the size. What are the L12, L23, L34, etc #s? Feel free to pm me if we shouldn't take focus away from Dag's topic. I'm not trying to hijack, Dag - promise.
Old 8th January 2012, 11:59 AM   #69
r23d is offline r23d  Australia
Default Looks like this box meets the single sheet challenge too...
Nice work Dag
Old 8th January 2012, 12:49 PM   #70
Sorry, my mistake - just a little more than 1, but still neat...
40Hz THHide this!Advertise here!
Help needed 40Hz to 450Hz 3GGG Multi-Way 10 8th February 2011 05:32 AM
DIY 40HZ TH for DJ use NEO Dan Subwoofers 10 29th January 2010 08:56 AM
40hz seems too much Kelloggrice Subwoofers 7 29th March 2007 12:30 PM
I want a subwoofer flat from 10hz-40hz Audiophilenoob Subwoofers 123 13th December 2005 05:10 AM
40hz horn modeled mikee12345 Multi-Way 0 30th September 2003 05:45 AM
