40Hz TH
40Hz TH
Old 13th December 2011, 03:54 PM   #51
reminence is offline reminence  Australia
Really 150lbs? the ss15 is 50-55lbs and has roughly the same dimensions, yes the driver is 17lbs lighter but still 150.. really?
Old 13th December 2011, 03:58 PM   #52
tb46 is offline tb46  United States
The SS15 is designed with 1/2" plywood.
Oliver
Old 13th December 2011, 04:13 PM   #53
m R g S r is offline m R g S r  United States
It's just a rough guess. But a high powered cabinet should be braced So bracing and a dense high quality 3/4" (Baltic or apple ply) weighs a good bit more than 1/2".
One 4x8 sheet of 3/4" is about 75lbs. The lab 15 driver is 27. I'm not sure, but I don't think this is a single sheet design.
Old 13th December 2011, 04:39 PM   #54
Dag Johansen is offline Dag Johansen  Norway
It is constructed from 15mm and 18mm plywood.
The total weight is around 105Lbs.
@ reminence:
I would not recomend Lab-12 in this design, the result is too bumpy, even when narowing the internal width to 16 inches.
Anyway, these cabs are easy to drag around, play loud even if you use only one.
It seems to play deeper than they simulate.
(either that or im too used to listen to double 18's )
Dag
Old 13th December 2011, 04:54 PM   #55
And some more numbers:
Dag
Old 13th December 2011, 08:14 PM   #56
scameron78 is offline scameron78  United States
The peavey lowrider 15 sims pretty good if i have the input for the driver correct.
Old 14th December 2011, 02:55 AM   #57
Ok, could this design be made of MDF and if so would it need to be thicker? I doubt I can get decent plywood where I live at all.
Old 14th December 2011, 03:41 AM   #58
Well MDF dents pretty easily and Weighs a ton. So I'd highly suggest NOT using it...but can you? Sure you CAN do whatever you want....
Old 19th December 2011, 12:32 AM   #59
Is there no way to get this design to be a carry-able weight (one person) ie 30-34kgs? if I use thinner material and this driver? JDs Sound and Lighting. Ande 15" LB15-1 350W driver / speaker
Old 19th December 2011, 12:35 AM   #60
I think the size is more of a problem to carry it. It would really kill your back to lift this thing in such an awkward position. I've lifted my TH-18's by myself but I'm 240lbs lol it wasn't easy. And after doing it once I said never again and fitted it with casters.
Just use casters there's a perfect spot for them to attach to the lower rear of the cabinet.
40Hz THHide this!Advertise here!
Help needed 40Hz to 450Hz 3GGG Multi-Way 10 8th February 2011 05:32 AM
DIY 40HZ TH for DJ use NEO Dan Subwoofers 10 29th January 2010 08:56 AM
40hz seems too much Kelloggrice Subwoofers 7 29th March 2007 12:30 PM
I want a subwoofer flat from 10hz-40hz Audiophilenoob Subwoofers 123 13th December 2005 05:10 AM
40hz horn modeled mikee12345 Multi-Way 0 30th September 2003 05:45 AM
