Old 14th June 2011, 11:10 PM   #1
qguy is offline qguy  Canada
Send a message via AIM to qguy Send a message via MSN to qguy Send a message via Yahoo to qguy
Default Scan-Speak with Passive Radiator vs Sealed Peerless
Saw this at Solen.CA
30W/4558T00 31cm 51mm Al SCA Denmark SCAN-SPEAK
30W/0-00-00 Passive Rad 30W SCA Denmark SCAN-SPEAK
The box volume is 1.5 cubic feet (43L)
Could I do better, not louder, but faster/tighter using a single 12 inch Peerless XXLS in a sealed cabinet? . The Driver is the Peerless 830845 in a 2.6 cubic feet box
Application is for 2 channel only
na
Old 15th June 2011, 02:02 PM   #2
Pallas is offline Pallas  Pakistan
The ScanSpeak Discovery 12 is basically an XLS. The basket's a bit different, and it's made in Denmark like the original XLS's, but same basic driver.
The difference between the two will just be that the PR setup (assuming it's well done) will trade off bass below its designed cutoff for greater efficiency slightly above cutoff. What that means in audiophool terms, who knows?
Old 20th June 2011, 10:43 PM   #3
So assuming both has the necessary SPL for the room, which one would be better suited to a 2 channel audio system ?
na
compact sub - sealed or passive radiator? Bill poster Subwoofers 5 8th June 2010 03:19 PM
peerless xxls sealed -vs- peerless xls with passive radiator Naudio Subwoofers 8 23rd March 2008 09:00 PM
Peerless passive radiator models sploo Subwoofers 9 11th August 2007 08:42 AM
Scan speak Ring Radiator with phase plug is it better than Best of dynaudio tweeter? diysmartdeep21 Multi-Way 4 11th February 2005 09:48 AM
Page generated in 0.06291 seconds (70.31% PHP - 29.69% MySQL) with 10 queries
