First time designing a sub, please check my work
Old 16th August 2003, 10:02 PM   #1
mFinalHeaven is offline mFinalHeaven
Default First time designing a sub, please check my work
So I decided on the Peerless 831858 that is on sale at madisound. Using Winisd, I have decided to put it in a 32L box tune to 28Hz using two 1 in diameter 4in length ports.
The curve looks pretty flat and the extension and group seems good for music as far as I can tell with my limited knowledge. So how is this setup? Does it look alright? Any comment is appreciated. Thanks!
PS. This is a sub that will be eventually use with a pair of super elf or elf 1.5 as my computer sound system.
Old 17th August 2003, 04:45 AM   #2
Centauri is offline Centauri  Australia
I don't have specs of this particular driver to model it in my copy of Lspcad, however 1" diameter ports seems a little on the small side to eliminate air speed noises. May be better to use 2" or 3" ports and make them longer to get required tuning.
Cheers
Old 17th August 2003, 06:23 AM   #3
I calculated the port diameter and length via isd online and this give a vent mach less than 0.16 which should not give me any port noise.
Old 17th August 2003, 06:37 AM   #4
zx3chris is offline zx3chris
Send a message via AIM to zx3chris
never used the winisd online version--i suggest u download the alpha pro and use that.. possibly the online version is estimating at 1w of power---did you enter in the max power you will be deliving to the sub as a parameter as well??
-chris
Old 17th August 2003, 06:42 AM   #5
I put in 100 watts as the max power. Is this correct?
Old 17th August 2003, 06:47 AM   #6
just redid it with 150watts and its still fine.
Old 17th August 2003, 08:00 AM   #7
GM is offline GM  United States
GM's Avatar
Driver specs?
BTW, WINISD has errors in it, so be forewarned! Also, <5% mach vent speed (0.05) is where you need to be for best performance as long as the pipe doesn't get too long for the sub's intended BW. 16% will be audible unless some means is used to damp it, though I've had folks tell me that subs with a 20% calculated vent mach sound fine to them, so YMMV.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th August 2003, 08:02 AM   #8
mikee12345 is offline mikee12345  New Zealand
mikee12345's Avatar
yes i must compare sub sim,dosbox,winisd old,new and any other i can find...see what teh diff is
my winisd 33hz box turned out just how winisd said-=also a mate with a good spreadsheet double checked it
Old 17th August 2003, 09:28 AM   #9
Unixbox tells me I will have problems with that port size Guess its back to the drawing board. Thanks for pointing that out.
Old 17th August 2003, 03:19 PM   #10
OK
Found some specs on this driver. Lspcad shows for this box size & tuning minimum 2 ports 50mm dia (2") by 310mm long (12") - better would be 2 50mm ports 280mm long in a 49.8 litre box - tuning point would be 22.7Hz.
Cheers
First time designing a sub, please check my workHide this!Advertise here!
Sanity check - designing my speaker to be 8ohm amplifier friendly. owdi Multi-Way 4 1st November 2005 11:08 PM
Copyright ©1999-2017 diyAudio
