Old 13th June 2011, 06:53 AM   #1
Default Simple ported 8" splap-together project.
Greetings from Aus!
I've been a member for a little while and thought I better post something sooner or later. It might aswell be this simple little project. Nothing special or fancy, but does the job. Specially loaded in corner of the room. Both H/T and Stereo (hifi, 2ch, panned mono, what ever pleases... etc )
Moving on to the pics
Fellow aussies will recognise the do-the-job bits from Jaycar. The Peerles 83049 is a now discontinued model that I had from other projects and the ply is recycled from other off-cuts. The only new component is the amp and the port, even the screws are recycled.
What you can't see in the photos is the slaughter of the tennis balls and inside treatment with a product called Sound-Off, finished off with some light stuffing.
Cheers!
Old 13th June 2011, 07:17 AM   #2
Send a message via AIM to DigitalJunkie
Nice!
I like the half-tennis ball feet.
Old 13th June 2011, 08:08 AM   #3
Originally Posted by DigitalJunkie View Post
Nice!
thanks... their cheap & cheerfull. Someone suggested I should have left them flouro yellow.
Old 13th June 2011, 09:44 AM   #4
blakkshepeaudio's Avatar
I'm guessing that was not your interior designer........
Seriously though, how does it sound? I have always wondered how good those Jaycar sub amps are. Any comments?
Rgds,
Keith Arnold
blakkshepeaudio
Old 14th June 2011, 09:40 AM   #5
Rgds,
Keith Arnold
blakkshepeaudio
Keith, their pretty much do-the-job gear. I've had no issues, does exactly pretty much as they market it to do and has neat features for easy adaptability.
Sound wise I'm still playing with stuffing and port lenght and x-over point. At this stage, the longer port (230mm) has reduced some of the boom/peaks I was experiancing earlier on. When Im close to a sound I like, I will RTA to get a simple in-room understanding of what its peaks/dips are.
What has made a good difference is running it out of phase, the phase switch on the back of the amp made this easy. Basic tuning (ie gain, x over freq & phase) is easy on this amp, so i guess it gets bonus points for that. It doesn't get too hot and after 2 weeks of on/off listening hasn't skipped a beat.
What I would like is for it to go lower, but for that I'd like to step up to an 18" of some sort... big cone area, minimal movement...
Old 15th June 2011, 07:33 PM   #6
Per N is offline Per N  Denmark
Very nice feature with the tennis balls Do they do the job?
Old 19th June 2011, 12:36 AM   #7
the tennis balls work suprisingly well. if the cabinet was much heavier, maybe not. But at this weight it decouples nicely!
NP:"Simple Sounds Better" TGY:"Simple Food Better" Gyuri The Lounge 10 19th December 2009 09:03 PM
"Magga Amp Workshop" builds again (Simple 45 Project) Niila Tubes / Valves 1 3rd February 2009 08:51 PM
Front Ported Zaph zbm4 Project Thread BionicSniper Multi-Way 6 26th August 2008 03:58 PM
XXLS 10" Ported Sub LageB Subwoofers 1 8th June 2006 01:00 PM
Membrane to limit "unloading" in ported-type enclosures? Datoyminaytah Multi-Way 6 18th August 2004 05:36 PM
Page generated in 0.10168 seconds (81.33% PHP - 18.67% MySQL) with 10 queries
